SNMP charts show MBytes not Mbits
rbuckle
Post by rbuckle »
I am running Mikrotik routers at the front end of my network, the router/switch charting's legend show Mbps but the stats are not Mbps.
Our front door routers routinely have 500-700Mbp running through them at all times but the charting is only showing 100-200 of traffic. All i can surmise form the statistics is that the actual number could be MBits instead, that would make the number on the charts more credible.
Does anyone have any thoughts?
I am using the hypervisor VHD image of nagios.
Running:
Installed Version: 5.8.3
OS: CentOS 7
Nagios XI
Enterprise License
bwallace
Re: SNMP charts show MBits not Mbps
Post by bwallace »
What type of check are you running against these devices?
For example, check_snmp would just return the value for the oid in question, unaltered, meaning you would have to verify the format the devices send the info in.
Or, are you using a plugin that is specifically intended for bandwidth-type of data, such as this?
https://exchange.nagios.org/directory/P ... h3/details
rbuckle
Post by rbuckle »
I am using the Default check_xi_service_mrtgraf that is created when using the Switch/Router wizard.
I am pretty new to Nagio so Sorry if i sound stupid, i am still learning
Running:
OS: CentOS 7
Nagios XI
Enterprise License
bwallace
Post by bwallace »
I don't know of any 'know-it-alls' (well maybe in their own minds) so hey we're all learning, right?
I used the Switch/Router Wizard here and once there was enough data to report on, I could see that the report is Mb/s - so I'd have to say your theory is correct.
Hope this helps, but certainly let us know if you have any other questions.
bwallace
Post by bwallace »
To clarify, I ran a 'Bandwidth Usage Report' for one of the ports.
bwallace
Post by bwallace »
I was curious so I ran another test. I configured an additional switch but during step 2 of the Wizard set-up for Switch / Router, I specified bandwidth to be in kbps for this second switch (see scrnsht), where the 1st switch was left to the default of mbps.
After awhile a I ran a report for the 2nd switch and the output was in kbps.
Conclusion = the unit of measure in the report will be consistent with the unit of measure specified during step two of the set-up.
rbuckle
Post by rbuckle »
So can you think of a way that I can have my Nagios be in Mbits not Mbytes... to confirm, i work for a ISP so all measures are in bits...
Any Ideas?
Running:
OS: CentOS 7
Nagios XI
Enterprise License
bwallace
Post by bwallace »
I'm pretty sure like you already have it in Mbits (Mbps) as there is not an option in the Nagios XI Switch/Router Wizard for Megabytes per second. (MBps).
The options are Gbps, Mbps, kbps, bps.
BTW, when it comes to bandwidth reporting / monitoring, Nagios has another product dedicated just for such. Since you work for an ISP maybe this would be more suitable, at least in this scenario?
https://www.nagios.com/products/nagios- ... -analyzer/
rbuckle
Post by rbuckle »
If it is in Mbits then the math is way off... the router itself is reporting a lot higher ie. 8x the amount... it must have an incorrect legend, ie. does not know that it is pulling a number that is MBytes so it assumes Mbits
Running:
OS: CentOS 7
Nagios XI
Enterprise License
ssax
Dreams In Code
Post by ssax »
I've updated the script for you to output the proper data in bits (B/b=bps; K/k=Kbps; M/m=Mbps; G/g=Gbps):
check_rrdtraf_custom.zip
NOTE: You will need to delete the RRDs that you currently have for these checks /usr/local/nagios/share/perfdata/HOSTNAME/SERVICENAME.rrd
You will lose the current data that you have for the graphs (not the original MRTG RRDs but the ones used in the interface).
Please test it out and validate the data before implementing in production.
