Dashboard dashlets large after upgrade
timchin
Post by timchin »
Hi, there. I upgraded to NagiosXI 5.2.5 tonight and noticed that the graphs on all of our dashboards are much larger than before. To the point where our wallboard is a mess - Even with trying to reorganize everything to fit on screen.
I tried to resize the dashlets using the corner, but it has no effect on the actual size of the graph (just the blue window border).
Is there a way to resize the dashlets so we can make the best use of our wallboards and screens?
Any help is appreciated. Thanks!
Tim
ssax
Dreams In Code
Re: Dashboard dashlets large after upgrade
Post by ssax »
Does going to Admin > System Settings > Theme & Display tab and checking "Use Highcharts for Perfdata Graphs" fix the problem?
Thank you
timchin
Post by timchin »
Checking that made it look really weird. However, being on that page, I changed the theme to XI 2014 and that resolved the issue.
Thanks so much!
Tim
ssax
Dreams In Code
Post by ssax »
Awesome, nice troubleshooting! Can we go ahead and mark this as resolved and lock the thread?
timchin
Post by timchin »
Yep. Thanks again!
