new nagios install on manjaro ...
LithiumKid1976
Post by LithiumKid1976 »
Hi
I installed nagios core 4.1.1 on manjaro, using the arch linux install info.
but when i try to open the browser using my ipaddres http://x.x.x.x/nagios
i get the following error.
the following error was encountered:
Connection to x.x.x.x Failed
The system returned:
(61) Connection refused
The remote host or network may be down. Please try the request again.
Your cache administrator is webmaster.
any ideas on what i need to do to get this working? this is my 1st attempt at nagios :)
Re: new nagios install on manjaro ...
Can you provide the steps you used to install Core?
Also - are you running a GUI on manjaro?
LithiumKid1976
Hi
Thanks for the reply.
i installed is as per the instructions for arch, https://wiki.archlinux.org/index.php/Nagios
this is a GUI installed, but i did the install via CLI.
thanks
D
Did you make sure that httpd/nginx servce is running? Try to restart it from the CLI, and show the output.
LithiumKid1976
Hi
So, it looked like i didnt have nginx installed :oops:
i installed it, restarted httpd, nginx and nagios, and now i get the landing page for nginx, when i go to the hosts ip address.
but get the 404 error, when i go to x.x.x./nagios
Welcome to nginx!
If you see this page, the nginx web server is successfully installed and working. Further configuration is required.
For online documentation and support please refer to nginx.org.
Commercial support is available at nginx.com.
Thank you for using nginx.
nozlaf
Post by nozlaf »
That guide is not very good
I say that because it provides three examples of how to configure your webserver but never tells you that you should not have all three installed.
so you should choose one and configure it
so either remove apache or remove nginx and if you also installed lighthttpd remove that
Please remove nginx, and post your apache configuration.
LithiumKid1976
HI
thanks, yes i found the instructions very hard to follow :)
I have removed both lighttpd and nginx, here is the details for the apache config.
# Language settings
Include conf/extra/httpd-languages.conf
# User home directories
Include conf/extra/httpd-userdir.conf
# Real-time info on requests and configuration
#Include conf/extra/httpd-info.conf
# Virtual hosts
#Include conf/extra/httpd-vhosts.conf
# Local access to the Apache HTTP Server Manual
#Include conf/extra/httpd-manual.conf
# Distributed authoring and versioning (WebDAV)
#Include conf/extra/httpd-dav.conf
# Various default settings
Include conf/extra/httpd-default.conf
# Configure mod_proxy_html to understand HTML4/XHTML1
<IfModule proxy_html_module>
Include conf/extra/proxy-html.conf
</IfModule>
# Secure (SSL/TLS) connections
#Include conf/extra/httpd-ssl.conf
# Note: The following must must be present to support
# starting without SSL on platforms with no /dev/random equivalent
# but a statically compiled-in mod_ssl.
<IfModule ssl_module>
SSLRandomSeed startup builtin
SSLRandomSeed connect builtin
</IfModule>
1. Nagios
Include "conf/extra/nagios.conf"
1. PHP
Include "conf/extra/php5_module.conf"
/etc/httpd//conf/httpd.conf (END)
Looks good there - can you also post /etc/httpd/conf/extra/nagios.conf?
LithiumKid1976
Hi PLease see below, info from nagios.conf.
more /etc/httpd//conf/extra/nagios.conf
Alias /nagios "/usr/share/nagios/share"
<Directory "/usr/share/nagios/share">
# SSLRequireSSL
Options None
AllowOverride None
<IfVersion >= 2.3>
<lid-user
</IfVersion>
</Directory>
# SSLRequireSSL
Options None
AllowOverride None
<IfVersion >= 2.3>
<RequireAll>
Require all granted
# Require host 127.0.0.1
AuthName "Nagios Access"
AuthType Basic
AuthUserFile /etc/nagios/htpasswd.users
Require valid-user
</RequireAll>
</IfVersion>
<IfVersion < 2.3>
Order allow,deny
Allow from all
# Order deny,allow
# Deny from all
# Allow from 127.0.0.1
AuthType Basic
Require valid-user
</IfVersion>
</Directory>
