I've found a number of SNMPTT setup docs for receiving remote SNMP traps, all around older versions of CentOS and all having references to modules that can't be installed the way they were documented, and in the end, service fails to start. Is there any current documentation on how to install/setup SNMPTT for Nagios on Centos 7?
Thanks.
JR
snmptt setup for centos 7?
Re: snmptt setup for centos 7?
The link below are the instructions for integrating SNMP traps on Nagios XI but the install should work the same on your system. Try it out to see if this works.
https://assets.nagios.com/downloads/nag ... ios_XI.pdf
Thanks. That didn't seem to work. I'm going to read thru the errors and see what can be adjusted if anything but script started, immediately said No packet smnptt available then continued to fail. Below is the complete output.
[root@nagios tmp]# sh ./NagiosXI-SNMPTrap-setup.sh
Nagios XI SNMP Trap Support Installation
Installing Prerequisites
Loaded plugins: fastestmirror
base | 3.6 kB 00:00:00
extras | 3.4 kB 00:00:00
updates | 3.4 kB 00:00:00
updates/7/x86_64/primary_db | 3.1 MB 00:00:00
Determining fastest mirrors
* base: mirror.team-cymru.org
* extras: lug.mtu.edu
* updates: mirror.steadfast.net
No package snmptt available.
Resolving Dependencies
--> Running transaction check
---> Package net-snmp-perl.x86_64 1:5.7.2-24.el7 will be installed
Dependencies Resolved
Package Arch Version Repository Size
Installing:
net-snmp-perl x86_64 1:5.7.2-24.el7 base 335 k
Transaction Summary
Install 1 Package
Total download size: 335 k
Installed size: 1.1 M
Downloading packages:
net-snmp-perl-5.7.2-24.el7.x86_64.rpm | 335 kB 00:00:00
Running transaction test
Transaction test succeeded
Running transaction
Installing : 1:net-snmp-perl-5.7.2-24.el7.x86_64 1/1
Verifying : 1:net-snmp-perl-5.7.2-24.el7.x86_64 1/1
Installed:
Complete!
Loading mirror speeds from cached hostfile
---> Package perl-Sys-Syslog.x86_64 0:0.33-3.el7 will be installed
Installing:
perl-Sys-Syslog x86_64 0.33-3.el7 base 42 k
Transaction Summary
Install 1 Package
Total download size: 42 k
Installed size: 93 k
perl-Sys-Syslog-0.33-3.el7.x86_64.rpm | 42 kB 00:00:00
Running transaction
Installing : perl-Sys-Syslog-0.33-3.el7.x86_64 1/1
Verifying : perl-Sys-Syslog-0.33-3.el7.x86_64 1/1
Installed:
Complete!
Download & installing supporting files
--2016-03-11 07:36:35-- http://assets.nagios.com/downloads/support/snmptrap-bins.tar.bz2
Resolving assets.nagios.com (assets.nagios.com)... 72.14.181.71
Connecting to assets.nagios.com (assets.nagios.com)|72.14.181.71|:80... connected.
HTTP request sent, awaiting response... 301 Moved Permanently
Location: https://assets.nagios.com/downloads/support/snmptrap-bins.tar.bz2 [following]
--2016-03-11 07:36:35-- https://assets.nagios.com/downloads/support/snmptrap-bins.tar.bz2
Connecting to assets.nagios.com (assets.nagios.com)|72.14.181.71|:443... connected.
Length: 8720 (8.5K) [application/x-bzip2]
Saving to: ‘snmptrap-bins.tar.bz2’
100%[===================================================================================================================>] 8,720 --.-K/s in 0s
2016-03-11 07:36:35 (89.5 MB/s) - ‘snmptrap-bins.tar.bz2’ saved [8720/8720]
tar (child): bzip2: Cannot exec: No such file or directory
tar (child): Error is not recoverable: exiting now
tar: Child returned status 2
tar: Error is not recoverable: exiting now
./NagiosXI-SNMPTrap-setup.sh: line 64: cd: snmptrap-bins/: No such file or directory
cp: omitting directory ‘./nagios-4.1.1’
cp: omitting directory ‘./sendEmail-v1.56’
cp: omitting directory ‘./systemd-private-051cba023f894dbebc001519a6e4259c-httpd.service-G87RqJ’
cp: omitting directory ‘./systemd-private-051cba023f894dbebc001519a6e4259c-vmtoolsd.service-EJMj3V’
cp: omitting directory ‘./systemd-private-0eb0627db69b43019032b8516166c170-httpd.service-UvLeEl’
cp: omitting directory ‘./systemd-private-0eb0627db69b43019032b8516166c170-vmtoolsd.service-3R7Vvk’
Updating snmptt.ini
sed: can't read /etc/snmp/snmptt.ini: No such file or directory
Creating snmptrapd.conf
Adding the snmptt user to the nagios and nagcmd groups
usermod: user 'snmptt' does not exist
Modifying permissions
chown: cannot access ‘/etc/snmp/snmptt.ini’: No such file or directory
chown: cannot access ‘/etc/snmp/snmptt.conf’: No such file or directory
chown: cannot access ‘/usr/local/bin/addmib’: No such file or directory
chmod: cannot access ‘/usr/local/bin/addmib’: No such file or directory
chown: invalid user: ‘snmptt:snmptt’
chmod: cannot access ‘/var/spool/snmptt’: No such file or directory
chmod: cannot access ‘/var/log/snmptt’: No such file or directory
Adding firewall rules
grep: /etc/sysconfig/iptables: No such file or directory
The service command supports only basic LSB actions (start, stop, restart, try-restart, reload, force-reload, status). For other actions, please try to use systemctl.
Set up the snmptt daemon to start automatically on boot
as well as starting it now
Failed to execute operation: Access denied
Failed to start snmptt.service: Unit snmptt.service failed to load: No such file or directory.
Set up the snmptrapd daemon to start automatically on boot
Created symlink from /etc/systemd/system/multi-user.target.wants/snmptrapd.service to /usr/lib/systemd/system/snmptrapd.service.
SNMP Trap Support Installation Complete!
So I think I manually figured it out this time. It's running at least and think it's a nice minimal way to do it. Think the key was the epel support. See what I did below:
- yum -y install net-snmp net-snmp-perl
- yum install epel-release
- yum -y install snmptt
- vi /etc/sysconfig/snmptrapd and add OPTIONS="-On -Lsd -p /var/run/snmptrapd.pid"
- vi /etc/snmp/snmptrapd.conf add the next two lines:
- traphandle default /usr/sbin/snmptthandler
- disableAuthorization yes
- service snmptrapd start
- chkconfig snmptrapd on
- vi /etc/snmp/snmptt.ini
- Change #date_time_format = to date_time_format = %H:%M:%S %Y/%m/%d
- Change syslog_enable = 1 to syslog_enable = 0
- yum install perl-Sys-Syslog
- service snmptt start
- chkconfig snmptt on
The tar file is compressed with bzip2 and it wasn't installed on your system. If it was, it should of worked.
You can run this to install it.
yum install bzip2Be sure to check out our Knowledgebase for helpful articles and solutions!
