Can i use newest plugins with Older Nagios Install?
FTL
Post by FTL »
Im running Nagios 3.4.1 and 1.4.16 plugins on Ubuntu 12.04
Is it safe and ok to use the newest 2.1.1 plugins with Nagios 3.4.1 please?
TIA
Re: Can i use newest plugins with Older Nagios Install?
Yes, and the three commands you previously had listed should be all you need as long as your plugins install path is /usr/local/nagios/libexec/ -- otherwise, you may need to change the configure directory to match your current setup.
FTL
Post by FTL »
Thanks.
Installed and check_snmp now works :)
eloyd
Cool Title Here
Post by eloyd »
That is part of the beauty of Nagios: The core Nagios functionality is separate from the plugins. As long as the plugins follow the rules (https://assets.nagios.com/downloads/nag ... inapi.html) then they will always work.
@eloyd is right. Having things be so interchangeable like this creates a product with an endless reach.
Are we good to mark this thread as resolved @FTL?
FTL
Post by FTL »
Please, go ahead.
Thankyou
