NNA Offline Installation
We are trying to evaluate the NNA product and are unfortunately on a offline environment. Is there a offline installation package or a set of instructions including required packages we can use?
Re: NNA Offline Installation
We have plenty of docs available for Network Analyzer, but we do not yet have one for offline installs, unfortunately.
http://library.nagios.com/library/produ ... umentation
Until we write one, you'll have to refer to the 'fullinstall' script which I've attached, for identifying all of the required packages. The following doc mentions not only required packages, but also some of the necessary modifications to users/groups/permissions, etc.
https://assets.nagios.com/downloads/nag ... ctions.pdf
