Monitor base 64 certificate format expiry
raydha
Post by raydha »
Has anyone try to monitor / have script to monitor base64 certificate ?
normally in .cer or .crt format.
I would like to monitor the certificate expiry date.
note: it is not SSL certificate. It is a end user certificate.
regards,
nozlaf
Re: Monitor base 64 certificate format expiry
Post by nozlaf »
If you look at this plugin
https://exchange.nagios.org/directory/P ... te/details
then read the comments
someone has extended the script to read files
https://subversion.ceres.auckland.ac.nz ... ertificate
I have not tested it
but should work for you
Thanks @nozlaf!
Let us know if that helps.
Alternatively, here's the link to our exchange which has a few more results returned for 'client cert' -
https://exchange.nagios.org/index.php?o ... ent%20cert
raydha
Post by raydha »
rkennedy wrote:Thanks @nozlaf!
thanks nozlaf & rkennedy. i failed to get the revised version made by Mr. vladimir.mencl.
this is the link to grab the revised plugin "You are welcome to grab my version from https://subversion.ceres.auckland.ac.nz ... ertificate"
however, i did try one of the script shared https://gallery.technet.microsoft.com/s ... iscussions but still in configuration mode. may require assistance from creator.
hsmith
Agent Smith
Post by hsmith »
Let us know what you come up with.
Former Nagios Employee.
me.
raydha
Post by raydha »
i am stuck. the status show "CHECK_NRPE : Error - Could not complete SSH handshake."
Can you show us the full command your inputting to receive that?
