Statusmap 3.5.1
rumarcin11
Statusmap 3.5.1
I would like to divide the hosts, because now I have that all hosts are podłaczonie to a tree, "N" and I'd like to hosts were Connect PC to the router as konfogurować and the place is set
Re: Statusmap 3.5.1
you need to set the parent (źródło) (Hope that is the correct word) of each host to be the actual parent
so
a typical host may or may not look like this
notice the
that makes the "SERVER1" a child of "router"
and ultimately to make everything work best make localhost (assuming that if what your nagios host is called in nagios) a parent of the router
so
define host {
host_name
alias SERVER1
address SERVER1
action_url /pnp4nagios/graph?host=$HOSTNAME$
notification_interval 15
notification_options d,u,r
max_check_attempts 3
active_checks_enabled 1
notifications_enabled 1
check_period 24x7
notification_period workhours
contact_groups Helpdesk
parents router
parents router and ultimately to make everything work best make localhost (assuming that if what your nagios host is called in nagios) a parent of the router
Re: Statusmap 3.5.1
Thanks @nozlaf!
@rumarcin11 - let us know if that is what you were looking for.
rumarcin11
Re: Statusmap 3.5.1
So everything worksrkennedy wrote:Thanks @nozlaf!
Re: Statusmap 3.5.1
Glad we were able to help. We'll lock this thread now and feel free to open another should you require assistance with anything else.
