Nagios XI 5 - restapi php
krobertson71
Post by krobertson71 »
Had great success using the command line 'curl' to add hosts/services in mass.
What I would like to do is have a simple php page where a user could enter a host name and then all the baseline checks are implemented.
Just curious if anyone has tried this. I have poured over PHP Curl docs but they don't seem to fit what I am trying to do.
BanditBBS
Re: Nagios XI 5 - restapi php
Post by BanditBBS »
I've done it :)
I wrote it as a component with a crazy amount of coding. I can share, but it'd need cleaned up bad as it has my API key and other items hardcoded...you'd have to redo a bunch, but it'd be a start.
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
krobertson71
That would be a great help. Thanks!
BanditBBS
Post by BanditBBS »
Attached! Good luck figuring out my hacked code :)
It adds to the menu on the left when you click "Configure" across the top menu. Advanced users can see it. At the bottom of the addl and addw files there are two different options for applying the changes remarked out, one gives a link and the other auto does it. I am having a service receive a passive check and alert me so I can manually apply changes when I want.
Edit #1 - I redacted URL and APIKey in all the files
Edit #2 - We are a hosting company, all customers have their own templates and stuff, you'll see the code that figures that all out, just wanted to explain that.
Edit #3 - You'll also see it sends a passive result to the same "Host Automation" service if for some reason an API call fails so that my team and figure the issue and get the host added
Edit #4 - Woot, my 2000th post!
krobertson71
Great stuff!!
This will help a lot. I wasn't sure you could just echo the curl url with the post variables and have it work.. Bravo.
So just echo $result does the trick? Just making sure my above statement was correct...
BanditBBS
Post by BanditBBS »
I put the command within ` marks(same key as ~) assigning it to a variable, that runs the command. No echo was used except to actually echo text.
krobertson71
Got ya. This is nice. Just need to chop some stuff out as we use NCPA, but this makes sense to me. GO ME!
Thanks for the help. Greatly appreciated!!!
Thanks for sharing, BanditBBS!
@krobertson71
Is it all right to lock this thread?
WillemDH
Post by WillemDH »
Congrats! :D
I'll have a look at your component too. Tx
Nagios XI 5.8.1
https://outsideit.net
WillemDH
Post by WillemDH »
So I had a look at the component. It definitely is a nice starting point for more customization. Would be nice to see this in GitHub? :)
Nagios XI 5.8.1
