Hi there,
I just migrated from CentOS 5.4 with FAN (Nagios + Centreon) to CentOS 7 with Nagios Core 4.1.1
On the old version, I had a ESXI Hardware check script, but sadly enough it's not working on the new host.
I keep receiving the following error in Nagios:
(No output on stdout) stderr: Traceback (most recent call last):
Does anyone has any idea what the issue could be?
Attached are the script files.
Kind regards,
Justin
No output on stdout
Justin2501
No output on stdout
- esxi_hardware.rar
- ESXI Check hardware
- (21.37 KiB) Downloaded 234 times
Re: No output on stdout
What are the permissions on these files? From the CLI, run ls -la /usr/local/nagios/libexec/check_esxi_hardware* and post back the result.
Justin2501
I've run the command:rkennedy wrote:What are the permissions on these files? From the CLI, run ls -la /usr/local/nagios/libexec/check_esxi_hardware* and post back the result.
[root@nagios ~]# ls -la /usr/local/nagios/libexec/check_esxi_hardware*
-rwxr-xr-x 1 nagios nagios 30735 Mar 12 2013 /usr/local/nagios/libexec/check_esxi_hardware.py
-rwxr-xr-x 1 nagios nagios 14780 Mar 12 2013 /usr/local/nagios/libexec/check_esxi_hardware.pyc
-rwxr-xr-x 1 nagios nagios 14780 Mar 12 2013 /usr/local/nagios/libexec/check_esxi_hardware.pyo
Do i need any specific packages, that i might be missing?
Or is this error something else
Justin2501
Hmm, i think i fixed it while trying out some stuff.
Downloaded the newest version of check_esxi_hardware
And installed the following python packages
After that i reloaded nagios and now it's working
http://www.claudiokuenzler.com/nagios-plugins/check_esxi_hardware.php#DownloadCode: Select all
yum install pywbem python-setuptoolsRe: No output on stdout
Thanks for that update and glad to hear this is resolved. I'll go ahead and close this thread now.
