Hi ,
I have setup one plugin which tells about the oracle version installed on windows and linux. I am trying to set command configuration but not able to.
Script is working fine from command line, but i am not able to set the commmand. i want to configure for all servers. can any one guide?
Here is the Plugin :
http://nagios.fm4dd.com/howto/db-monitoring.htm
Usage: java check_dbversion_oracle <db-ip> <db-port> <db-instance> <db-user> <db-pwd> [-d]
java -classpath /usr/local/nagios/libexec/ check_dbversion_oracle 172.26.2.15 1521 oracle monora "m0n0ra7"
Version OK: Oracle v11.2.0.4.0|Oracle Database 11g Enterprise Edition v11.2.0.4.0
Can any one help here.
Help In Setting Up Command Configuration
Re: Help In Setting Up Command Configuration
Can you show us the working command line output?
Former Nagios Employee.
me.
me.
My Command Line Output :hsmith wrote:Can you show us the working command line output?
[root@vmcloudtest libexec]# java -classpath /usr/local/nagios/libexec/ check_dbversion_oracle 172.26.2.15 1521 oracle monora "m0n0ra7"
if i am checking through Console, its giving no output (screenshot attached)
You may need to use the full path to java, what is the output of whereis java?
To add to that, what are the permissions of check_dbversion_oracle? ls -l /usr/local/nagios/libexec/check_dbversion_oracle
Lastly, your command line looks off, you'll need to add at least $HOSTADDRESS$ to the end of the command defined in the XI interface. You'll then need to decide if you are setting 'oracle monora "m0n0ra7" through the service as $ARG1$, or if you statically define it in the command. The choice is yours, as to what will make the best use in your environment.
rkennedy wrote:You may need to use the full path to java, what is the output of whereis java?
Hi rkennedy,
I have done the modifications, as you suggested but still output is coming same as above (screenshot attached). Also there is no file check_dbversion_oracle.
java Location :
[root@VM-NAGIOSXI-TEST bin]# whereis java
java: /usr/bin/java /etc/java /usr/lib/java /usr/share/java /usr/share/man/man1/java.1.gz
Please check the plugin page : http://nagios.fm4dd.com/plugins/manual/ ... oracle.htm
Let me how i can get the output in nagios dashboard ?
The test check over the web interface can have issues. What is the result of the service check that's running over the web interface?rkennedy wrote:To add to that, what are the permissions of check_dbversion_oracle? ls -l /usr/local/nagios/libexec/check_dbversion_oracle
For that service that's running the check, did you set $ARG1$ to oracle monora "m0n0ra7"? Can you paste a screenshot of that page from the CCM?
When i am running the same command on CLI, i am getting the correct output, when i am trying to run from web-interface i am getting blank output.rkennedy wrote:The test check over the web interface can have issues. What is the result of the service check that's running over the web interface?rkennedy wrote:To add to that, what are the permissions of check_dbversion_oracle? ls -l /usr/local/nagios/libexec/check_dbversion_oracle
I'd like to rule out permissions, when you run it over the CLI, can you attempt to do so as the nagios user and post the result?
Hi rkennedy,rkennedy wrote:I'd like to rule out permissions, when you run it over the CLI, can you attempt to do so as the nagios user and post the result?
Here is the output when run the command using nagios user :
[nagios@VM-NAGIOSXI-TEST libexec]$ java -classpath /usr/local/nagios/libexec/ check_dbversion_oracle 172.26.2.15 1521 disney monora m0n0ra7
its giving the output.
This command has a different syntax then the above screenshot. Can you add disney to your check_db_version command after 1521 so that the parameters pass properly?CloudOps wrote:Hi rkennedy,rkennedy wrote:I'd like to rule out permissions, when you run it over the CLI, can you attempt to do so as the nagios user and post the result?
