Monitor https port in a non default port error
rohithroki
Dear Team,
I am trying to configure https port for a non default port in nagios using the below command.
# ./check_http -S -H x.x.x.x -p 8080
I am getting the below error for the command
CRITICAL - Cannot make SSL connection.
139738252154728:error:140770FC:SSL routines:SSL23_GET_SERVER_HELLO:unknown protocol:s23_clnt.c:769:
Kindly help me in fixing the error.
regards,
RKJ
regards,
RKJ
Re: Monitor https port in a non default port error
I assume the webpage is working when you browse to
https://x.x.x.x:8080
What happens if you try:
./check_http -H x.x.x.x -p 8080Rob Hassing
Thanks @rhassing!
@robithroki - let us know the result.
rohithroki
hi rkennedy,rhassing
Thank you for your reply and apologies for the delay.
i have executed the below command in the nagios server and getting the below error
CRITICAL- Socket time out after 10 seconds
i have increased the time interval and checked and still i get the same error.Also telnet works fine for the below port .
regards,
RKJ
regards,
RKJ
What application is running on port 8080?
From the Nagios machine, please post the result of nmap x.x.x.x (where x.x.x.x is the IP you're attempting to monitor)
rohithroki
@rkennedy
please find the results of nmap command
8080/tcp open http-proxy
Regards,
RKJ
Regards,
RKJ
Weird, the port is open. Let's dig into it with curl.
Can you please run the following, and post the output back?
curl -v "https://x.x.x.x:8080"
rohithroki
please find the result of curl command below
* About to connect() to x.x.x.x port 8080 (#0)
* Trying x.x.x.x... connected
* Connected to x.x.x.x (x.x.x.x) port 8080 (#0)
* Initializing NSS with certpath: sql:/etc/pki/nssdb
* CAfile: /etc/pki/tls/certs/ca-bundle.crt
CApath: none
* NSS error -12263
* Closing connection #0
* SSL connect error
curl: (35) SSL connect error
CApath: none
* NSS error -12263
* SSL connect error
and what about:
curl -v "http://x.x.x.x:8080"Rob Hassing
rohithroki
please find the curl results for http
> GET / HTTP/1.1
> User-Agent: curl/7.19.7 (x86_64-redhat-linux-gnu) libcurl/7.19.7 NSS/3.16.2.3 Basic ECC zlib/1.2.3 libidn/1.18 libssh2/1.4.2
> Host: x.x.x.x:8080
> Accept: */*
< HTTP/1.1 404 Not Found
< Content-Type: text/html; charset=ISO-8859-1
< Cache-Control: must-revalidate,no-cache,no-store
< Content-Length: 284
< Server: Jetty(9.2.1.v20140609)
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8"/>
<title>Error 404 Not Found</title>
</head>
<body><h2>HTTP ERROR 404</h2>
<p>Problem accessing /. Reason:
<pre> Not Found</pre></p><hr><i><small>Powered by Jetty://</small></i><hr/>
</body>
</html>
* Connection #0 to host x.x.x.x left intact
> GET / HTTP/1.1
> Host: x.x.x.x:8080
> Accept: */*
<html>
<head>
</head>
</body>
</html>
