Hi i'm trying to monitor a port by using port monitoring wizard but when i have tried to monitor a port number 6129 which is used by DamWare application i'm getting error as socket timeout after 10 seconds i have mentioned TCP port.
Thanks in advance
Port Monitoring
Re: Port Monitoring
Can you test the port using the CLI plugin? From the command line of your nagios XI server go to the libexec directory
cd /usr/local/nagios/libexec/
And then execute this:
./check_tcp -H <your server address> -p <port number>
Nicholas Scott
nagiostool
Re: Port Monitoring
i have run the command in /usr/local/nagios/libexec
as ./check_tcp -H 192.168.10.120 -p 6129
result was
Connection refused.
result was
Connection refused.
Re: Port Monitoring
Well then the port is probably closed. Can you try to telnet into that port? Are you absolutely sure the DamWare application is actually using that port?
Nicholas Scott
nagiostool
Re: Port Monitoring
i was able to telnet to that port , didnt get any error.
Damware uses that port only
Re: Port Monitoring
Is the DamWare using udp? Try the check_udp plugin instead of the check_tcp plugin.
Nicholas Scott
nagiostool
Re: Port Monitoring
while using UDP what should be entered in the send string and expected string coloumns ??
Can you guide me ??
Can you guide me ??
Re: Port Monitoring
There is a pretty good breakdown of all the flags here:
http://nagiosplugins.org/man/check_udp
But the send string is the string that you would send to the server, and the expected string is the string it should send back. So if you were testing HTTP, you would send it a SYN string and expect an ACK string back. Thats what thats for.
But I would just test to see if its open, all arguments besides hostname and port are optional.
Nicholas Scott
