Nagios is not able to be logged in from GUI
amit.ahuja
Post by amit.ahuja »
We are currently having trouble login to Nagios from GUI. We used the username and password, which were correct for sure, and clicked the login button. Then, the page was refreshed but sent us back to the login page again. It seems clicking on the login button just refresh the page without actually login.
Thanks in advace
hsmith
Agent Smith
Re: Nagios is not able to be logged in from GUI
Post by hsmith »
Can you log in to core?
http://x.x.x.x./nagios instead of http://x.x.x.x/nagiosxi
Former Nagios Employee.
me.
amit.ahuja
Yes, I can log into core.
hsmith
Agent Smith
Post by hsmith »
What are the contents of /etc/httpd/conf.d/nagiosxi.conf?
me.
amit.ahuja
<Directory "/usr/local/nagiosxi/html">
# SSLRequireSSL
Options None
AllowOverride None
Order allow,deny
Allow from all
# Order deny,allow
# Deny from all
# Allow from 127.0.0.1
# AuthName "Nagios XI"
# AuthType Basic
# AuthUserFile /usr/local/nagiosxi/etc/htpasswd.users
# Require valid-user
</Directory>
Alias /nagiosxi "/usr/local/nagiosxi/html"
<IfModule mod_rewrite.c>
RewriteEngine On
RewriteCond %{REQUEST_FILENAME} !-f
RewriteCond %{REQUEST_FILENAME} !-d
RewriteRule nagiosxi/api/v1/(.*)$ /usr/local/nagiosxi/html/api/v1/index.php?request=$1 [QSA,NC,L]
</IfModule>
You can reset the nagiosadmin password with the following script
/usr/local/nagiosxi/scripts/reset_nagiosadmin_password.php --password=<newpassword>
amit.ahuja
Hi, I reset the password, but the same issue still exists. It does not seem like the password authorization problem, because it does not prompt the username or password is wrong, just refreshes the login page.
Did you modify any of the httpd configuration files?
Any mysql errors?
tail -f /var/log/mysqld.log
Finally, you do have cookies and sessions enabled in your browser correct?
amit.ahuja
I did not modify any of the httpd configuration files. In mysqld.log, i saw some errors as below,
160322 11:23:00 [ERROR] /usr/libexec/mysqld: Can't create/write to file '/var/run/mysqld/mysqld.pid' (Errcode: 13)
160322 11:23:00 [ERROR] Can't start server: can't create PID file: Permission denied
Also, I found I was not able to run /usr/local/nagiosxi/scripts/reconfigure_nagios.sh. I gave me this error.
PHP Warning:  PHP Startup: Unable to load dynamic library '/usr/lib64/php/modules/mcrypt.so' - /usr/lib64/php/modules/mcrypt.so: cannot open shared object file: No such file or directory in Unknown on line 0
URL: http://localhost/nagiosxi/includes/components/ccm/
CMDLINE:
/usr/bin/wget --load-cookies=nagiosql.cookies http://localhost/nagiosxi/includes/components/ccm/ --no-check-certificate --post-data 'cmd=apply&type=writeConfig' -O nagiosql.export.monitoring
--2016-03-22 15:37:13--  http://localhost/nagiosxi/includes/components/ccm/
Resolving localhost... 127.0.0.1
Connecting to localhost|127.0.0.1|:80... connected.
Length: unspecified [text/html]
Saving to: “nagiosql.export.monitoring”
    [ <=>        ] 9,860       --.-K/s   in 0.02s
2016-03-22 15:37:14 (538 KB/s) - “nagiosql.export.monitoring” saved [9860]
NAGIOSQL WRITE CONFIGS FAILED!\n
amit.ahuja
The only thing I did before this happens was that I changed the user of the directories in /var to nagios, then accessing web interface showed we needed to repair db. Then I changed the user back to root, then we were still not able to login.
