Check Disk Unix I/O
murawweh.daher
Check Disk Unix I/O
i installed nrpe agent on solaris10 and want to check disk i/o, i tried to use check_iostat plugin but everytime have error as below.
what is the best way to check disk load for solaris 10?
./check_iostat -h
./check_iostat: function: not found
-e
This plugin shows the I/O usage of the specified disk, using the iostat external program.
It prints three statistics: Transactions per second (tps), Kilobytes per second
read from the disk (KB_read/s) and and written to the disk (KB_written/s)
./check_iostat:
-d <disk> Device to be checked (without the full path, eg. sda)
-c <tps>,<read>,<wrtn> Sets the CRITICAL level for tps, KB_read/s and KB_written/s, respectively
-w <tps>,<read>,<wrtn> Sets the WARNING level for tps, KB_read/s and KB_written/s, respectively
./check_iostat: -1: bad number
./check_iostat -h
-e
./check_iostat:
Regards,
Murawweh Daher
Murawweh Daher
murawweh.daher
Re: Check Disk Unix I/O
!/bin/sh
# Version 0.0.2 - Jan/2009
# Changes: added device verification
# by Thiago Varela - [email protected]
please find attached file (please remove .txt just for uploading)
Regards,
Murawweh Daher
Murawweh Daher
If you edit that plugin and remove the following lines from it, that message will go away.
Solaris's command shell doesn't work with functions used in scripts.
Try that and see if it works for you.
function help {
echo -e "\n\tThis plugin shows the I/O usage of the specified disk, using the iostat external program.\n\tIt prints three statistics: Transactions per second (tps), Kilobytes per second\n\tread from the disk (KB_read/s) and and written to the disk (KB_written/s)\n\n$0:\n\t-d <disk>\t\tDevice to be checked (without the full path, eg. sda)\n\t-c <tps>,<read>,<wrtn>\tSets the CRITICAL level for tps, KB_read/s and KB_written/s, respectively\n\t-w <tps>,<read>,<wrtn>\tSets the WARNING level for tps, KB_read/s and KB_written/s, respectively\n"
exit -1
}Try that and see if it works for you.
murawweh.daher
./check_iostat -d / -w 1,2,3 -c 2,3,4
ERROR: Device incorrectly specified
./check_iostat: help: not found
./check_iostat: test: unknown operator ==
./check_iostat: [[: not found
./check_iostat: : cannot execute
./check_iostat: test: unknown operator 2 | bc
./check_iostat: test: unknown operator 1 | bc
OK - I/O stats tps= KB_read/s= KB_written/s= | 'tps'=; 'KB_read/s'=; 'KB_written/s'=;
Regards,
Murawweh Daher
Murawweh Daher
I believe it's looking for a mount, not just /.murawweh.daher wrote:./check_iostat -d / -w 1,2,3 -c 2,3,4
murawweh.daher
Use "sda", instead of "/". Example:
[root@192 tmp]# df -h
rootfs 9.4G 6.1G 3.3G 66% /
devtmpfs 2.0G 140K 2.0G 1% /dev
tmpfs 2.0G 0 2.0G 0% /dev/shm
/dev/sda1 9.4G 6.1G 3.3G 66% /
[root@192 tmp]# ./check_iostat.sh -d sda1 -w 1,2,3 -c 2,3,4
CRITICAL - I/O stats tps=7.46 KB_read/s=3.35 KB_written/s=174.58 | 'tps'=7.46; 'KB_read/s'=3.35; 'KB_written/s'=174.58;Be sure to check out our Knowledgebase for helpful articles and solutions!
murawweh.daher
i test on Linux and worked fine.
./check_iostat -c 20,20,20 -w 10,10,10 -d sda
CRITICAL - I/O stats tps=232.33 KB_read/s=238.10 KB_written/s=5615.89 | 'tps'=232.33; 'KB_read/s'=238.10; 'KB_written/s'=5615.89;
but on Solaris 10 didn't work.
Regards,
Murawweh Daher
Murawweh Daher
Can you post the full input / output when you attempt it on the Solaris machine?
