Required Custom Feature
rlinux57
Post by rlinux57 »
Any option if we can show servers uptime to public using nagios core ?
rhassing
Re: Required Custom Feature
Post by rhassing »
You could use a plugin which monitors the uptime.
I would use snmp to monitor this:
#!/bin/sh
# 2003-01-11, Fredrik Wanglund
# This plugin gets the uptime from a host via snmp.
# To use the plugn, do the following:
# First, create a checkcommand (typically in etc/checkcommands.cfg):
# define command {
# command_name                    uptime_by_snmp
# command_line                    /usr/lib/nagios/plugins//uptime_by_snmp $HOSTADDRESS$ $ARG1$
  =f your Nagios-plugin is not located in /usr/lib/nagios/plugins//,
# You have to change the path in the command-definition AND the
# variable NAGIOSPLUGSDIR below.
# Second, Add a service-definition (typically in etc/services.cfg):
# define service {
# host_name                      server
# service_description            Uptime
# check_command                  uptime_by_snmp!public
# use                            generic-service
# normal_check_interval          10
# Replace the 'use' statement with whatever template you would like to use,
# or fill up the definition with required parameters if you dont want to
# use any template.
# The arguments to the 'check_command' is:
# 1) The command-name, disk_by_snmp
# 2) The SNMP community-string
# READY.
# Change this if you have installed NAgios in a non-default place:
NAGIOSPLUGSDIR=/usr/lib/nagios/plugins
UPTIMESDIR=/tmp/uptimes
UPT=`$NAGIOSPLUGSDIR/check_snmp -H $1 -o .1.3.6.1.2.1.1.3.0 -C $2`
RES=$?
if [ $RES = 0 ]; then
        TICKS=`echo $UPT|cut -d "(" -f 2|cut -d ")" -f 1`
        if [ -f $UPTIMESDIR/$1 ]; then
                if [ -s $UPTIMESDIR/$1 ]; then
                        MAXTICKS=`cat $UPTIMESDIR/$1|cut -d ":" -f 2`
                else
                        MAXTICKS=0
                fi
                if [ $TICKS -gt $MAXTICKS ]; then
                        DATE=`date "+%s"`
                        echo "$DATE, $1, $MAXTICKS, $TICKS" >> /tmp/ticks
                        echo "$DATE:$TICKS" > $UPTIMESDIR/$1
                fi
        else
        echo "$1: $TICKS" >> /tmp/ticks
        fi
        RET=`echo $UPT|cut -d ")" -f 2`
else
        RET=$UPT
        RES=1
fi
RET="Uptime: $RET"
echo $RET
exit $RES
Rob Hassing
I think OP is asking how to expose the Core web interface to the public - is this correct, @rlinux57?
If that's the case, you could add in a contact called "public" or "guest" or something similar, and give it the appropriate permissions to suit your needs:
https://assets.nagios.com/downloads/nag ... iauth.html
Then either hand out the credentials, display the information on-screen publicly, or use another frontend to parse out that information and display it.
rlinux57
Post by rlinux57 »
Yes @tmcdonald, i want to show server's uptime to my clients.
Does the above solution that @tmcdonald posted work for you? With read only permissions they'll be able to take a look at the system, but not make any changes.
rlinux57
Post by rlinux57 »
Somehow, but need your help. After creating user by below command, how can i gave privileges to my clients to access and read only uptime status of several servers. ?
htpasswd /usr/local/nagios/etc/htpasswd.users <username>
You will need to modify /usr/local/nagios/etc/cgi.cfg in order to do this, and modify the following -
authorized_for_all_services=nagiosadmin
authorized_for_all_hosts=nagiosadmin
To add a read only user -
authorized_for_all_services=nagiosadmin,readonlyuser
authorized_for_all_hosts=nagiosadmin,readonlyuser
rlinux57
Post by rlinux57 »
Is it possible to define only specific hosts and services for read only users. ?
Take a look at this guide to see if this is what you are looking for.
If they are setup as a contact for that host / service, then that is all they will see.
rlinux57
Post by rlinux57 »
I have do it but didn't find any suitable option that i want. I just need to show information to client as mentioned in screenshot. please find attachment.
