Dependencies Issues
Ticcio
Dependencies Issues
Post by Ticcio »
Hi!
I'm configuring my first dependencies ever and I have a few questions since they are not working.
Basically, a rough map could be this one
+Host1
+-AsteriskServiceCheck
+--CallsCheck
+--ChannelsCheck
and on..
Since i have more than one host that needs this dependency I found this on the documentation:
define servicedependency{
		host_name			HOST1,HOST2
		service_description		SERVICE1,SERVICE2
		dependent_service_description	SERVICE3,SERVICE4
		other dependency directives ...
I tried and wrote it down:
	host_name				JustAppRH01,JustAppRH02,Just-MSApp01
	service_description 			check_asterisk_calls,check_asterisk_channels,check_asterisk_sippeers,check_asterisk_iaxpeers
	dependent_service_description 	check_asterisk
	execution_failure_criteria		w,u,c,p
	notification_failure_criteria	w,u,c,p
But still it will send me notifications on those services, instead of just the "check_asterisk" one.
Am I writing it wrong?
Thanks for the help
bwallace
Re: Dependencies Issues
Post by bwallace »
It looks like you have it flipped. For your service_description you should only have check_asterisk defined (Note: there must be an actual service called by this name)Then place all your other services who are dependent upon check_asterisk on the line for dependent_service_description
Ex:
dependent_service_description    check_asterisk_calls,check_asterisk_channels,check_asterisk_sippeers,check_asterisk_iaxpeers
Ticcio
Post by Ticcio »
Oh, well that's kinda embarassing.
Thank you for the help! Sorry for the delay!
bwallace
Post by bwallace »
Hey no worries, glad it's straightened out! I'll go ahead lock this thread now - have a good day -
