Hi All,
Can anyone guide me how i can enable PNPgraph in Nagiosxi?
Shailesh
PNP Graph In Nagiosxi
Re: PNP Graph In Nagiosxi
Depending on your version, you might be using the Highcharts Javascript library for graph drawing instead of PNP. To switch back in XI 5+, go to Admin -> System Settings -> Theme & Display, and uncheck Use Highcharts for Perfdata Graphs, then save.
I have enbaled it now. but its not showing download option. any thing i have to do it for enabling the download of reports?tmcdonald wrote:Depending on your version, you might be using the Highcharts Javascript library for graph drawing instead of PNP. To switch back in XI 5+, go to Admin -> System Settings -> Theme & Display, and uncheck Use Highcharts for Perfdata Graphs, then save.
There is a check box to enable / display service performance graphs in reports, under the 'advanced' area from the Report configuration page:
