HI Support,
I have configured Nagios 4 on CentOS 6.6 64-bit server. And its working properly.
What is my issue is that, I have created a custom service definition for checking a custom service running OR Not. In the webpage, status of that particular service showing correctly. But I didn't getting any alert mail if the service Stopped ( Critical ). So is there any configuration missing for sending alert mail for any custom service.
Version : Nagios Core 4.0.4
OS: CentOS 6.6 64 bit
Checking service definition in Libexec
This is done by creating a simple bash script, which is
#vim /usr/loca/nagios/libexec/check_xxxx
#!/bin/bash
if ps ax | grep -v grep | grep /usr/sbin/XXXXD > /dev/null
then
echo "OK, XXXX service is running"
exit 0
else
echo "CRITICAL , XXXX service is not running"
exit 2
fi
Service definition in localhost.cfg
# vim /usr/local/nagios/etc/objects/localhost.cfg
use local-service ; Name of service template to use
host_name localhost
service_description XXXX Service
check_command check_xxxx
notifications_enabled 0
Command definition in commands.cfg
# vim /usr/local/nagios/etc/objects/commands.cfg
command_name check_xxxx
command_line $USER1$/check_xxxx -H $HOSTADDRESS$ $ARG1$
Kindly check this and advice me, what is the reason for alert mailings is not getting for this custom service check.
Thanks to all in advance.
Regards
Satheesh
Alert mail is not getting for a custom service check
[email protected]
Re: Alert mail is not getting for a custom service check
You will need to change notifications_enabled from 0, to 1. You'll also need to define a contact like so -
From there, you'll want to add the defined contact to your service definition, and also add notification_options. Here's an example -
Take a look at this link for a more in depth explanation. https://assets.nagios.com/downloads/nag ... tions.html
define contact{
contact_name nagiosadmin ; Short name of user
use generic-contact ; Inherit default values from generic-contact template (defined above)
alias Nagios Admin ; Full name of user
email [email protected] ; <<***** CHANGE THIS TO YOUR EMAIL ADDRESS ******
host_name linux-server
service_description check-disk-sda1
check_command check-disk!/dev/sda1
max_check_attempts 5
check_interval 5
retry_interval 3
check_period 24x7
notification_interval 30
notification_period 24x7
notification_options w,c,r
contacts nagiosadmin
notifications_enabled 1
[email protected]
Thanks rkennedy.....
I have made the changes as per your suggestion. Now its resolved and I am getting the alerts....
Once again thanks... : )(Y)
You're welcome -- glad it worked!
Closing this out now, but feel free to make a new thread if you need any assistance in the future!
