We are trying to install Nagios agent on Ubuntu servers. Version 14.04.3
we are executing the below commands and addition to that we are executing the command #./configure where ssl and ssl-lib files are added. In this ssl files are not available in the document which we are executing and let us know it will not affect any production changes while executing it.
Since we are getting below error while executing ./configure without the SSl-lib files.
#./configure --enable-command-args
configure: error: Cannot find ssl libraries
For installing Nagios in Ubuntu servers do we need to install nagios-agent and nrpe both document commands for successful installation.
Referring document Installing-the-Ubuntu-and-Debian-Agent-in-Nagios-XI
#add-apt-repository ppa:nagiosinc/ppa
#apt-get update
#apt-get install nagios-agent
#dpkg-reconfigure nagios-agent
Referring document How-To-Configure-NRPE-and-Install-From-Source-with-Nagios-XI
#cd /tmp
#wget http://sourceforge.net/projects/nagios/ ... .14.tar.gz
#tar vfxz nrpe-2.14.tar.gz
#cd nrpe-2.14
#./configure --with-ssl=/usr/bin/openssl --with-ssl-lib=/usr/lib/x86_64-linux-gnu which is not in document SSL
#make
#make install
#mkdir /usr/local/nagios/etc
#cp sample-config/nrpe.cfg /usr/local/nagios/etc
#cd /tmp/nrpe-2.14
#make install-xinetd
#Vi /etc/xinetd.d/nrpe
only_from = 127.0.0.1 x.x.x.x
(where x.x.x.x is your Nagios XI server's ip)
Finally, we need to add the nrpe port and service declaration in /etc/services:
#vi /etc/services
Add:
nrpe 5666/tcp
#service xinetd start
#cd /usr/local/nagios/libexec
#./check_nrpe -H localhost
You should see the following output:
NRPE v2.14
If you get the nrpe version number
#/tmp
#wget https://www.nagios-plugins.org/download ... 2.0.tar.gz
#tar zxvf nagios-plugins-2.0.tar.gz
#cd /tmp/nagios-plugins-2.0
#./configure --with-nagios-user=nagios --with-nagios-group=nagios
#make
#make install
To recap, nrpe and the nagios-plugins pack installed to /usr/local/nagios/libexec.
The nrpe.cfg config file is located at /usr/local/nagios/etc.
#vi /usr/local/nagios/etc/nrpe.cfg
allowed_hosts=127.0.0.1,<your Nagios XI IP address>
dont_blame_nrpe=1
#service xinetd status
If service not started start it.
Installing Nagios agent on Ubuntu servers
Beena_Jogin
Re: Installing Nagios agent on Ubuntu servers
Regarding the error "cannot find ssl headers" run this command apt-get install libssl-dev and (re) ./configure afterwards. This, nor any of the steps below, will have any impact on production.
I've seen with other NRPE installs on Ubuntu where after the above executes, you'll end up with a new error:
checking for SSL libraries... configure: error: Cannot find ssl libraries
If that is the case, you'll have to use 'apt-file' to search for where these SSL headers reside, so run the following:
apt-get install apt-file -y
Then run
apt-file update
Now you should be ready to actually use apt-file, like so:
apt-file search libssl |grep libssl-dev
You should see something similar to this:
Now you can reconfigure using the '--with-ssl-lib' option (run from the nrpe-* directory)
./configure --with-ssl-lib=/usr/lib/i386-linux-gnu/
Then run
apt-file update
libssl-dev: /usr/lib/i386-linux-gnu/libssl.a
libssl-dev: /usr/lib/i386-linux-gnu/libssl.so
libssl-dev: /usr/lib/i386-linux-gnu/pkgconfig/libssl.pc
libssl-dev: /usr/share/doc/libssl-dev/changelog.Debian.gz
libssl-dev: /usr/share/doc/libssl-dev/changelog.gz
libssl-dev: /usr/share/doc/libssl-dev/copyright./configure --with-ssl-lib=/usr/lib/i386-linux-gnu/
