Migrating to Centos from Ubuntu Server
nathanplatt
Post by nathanplatt »
Hi Guys,
I've spent a lot of time configuring Nagios and Graphs on Ubuntu but I want to look at Log Server as well, looking at it I can see that the manual install is set for Centos, so I was considering migrating the whole server to Centos.
Is it difficult to move everything, or is it as simple as compressing the following folders and moving them onto the new machine;
/usr/local/nagios
/usr/local/nagiosgraphs
/etc/apache2/
What are your thoughts? Or is there a way to install Log Server on Ubuntu?
nozlaf
Re: Migrating to Centos from Ubuntu Server
Post by nozlaf »
depends on how much you have done in your existing installation but generally just doing a fresh install in centos then copying the config from the old install to the new install will work
Currently Ubuntu is not supported as an OS for NLS. With that said, running Nagios Core and Nagios Log Server on the same server isn't reccomended either.
As for the migration - compile a new system with Core running, and then add in your configuration files. It shouldn't be too painful as long as you have some sort of organization in place for your definitions.
nathanplatt
Great thank you guys, you can close this thread
bwallace
Post by bwallace »
Glad we were able to help. We'll lock this thread now and feel free to open another should you require assistance with anything else.
