Upgrade to XI 5.2.6 broke a graph
BanditBBS
Post by BanditBBS »
So I just upgraded my dev server to XI 5.2.6 and one of the graphs on my dashboard is now showing up blank with the words "XSS Detected. Object does not exist"
I can't see any graphs for this service anywhere.
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
Re: Upgrade to XI 5.2.6 broke a graph
sed -i 's/nagiosccm_get_service_id/get_service_id/' /usr/local/nagiosxi/html/includes/components/graphexplorer/visFunctions.inc.php
Known issue, will be fixed in the next release.
BanditBBS
Post by BanditBBS »
didn't fix it. I verified the substitute worked, refreshed page source, closed all browsers, relaunched......Still showing the error on the graph on my home dashboard.
jomann
Development Lead
Post by jomann »
Hey Bandit,
What is the object that is having a problem? Is it a host or service and is it a static one from a configuration file or is it defined in the CCM?
BanditBBS
Post by BanditBBS »
Service defined in the ccm
Try this one:
sed -i 's/exit.*//' /usr/local/nagiosxi/html/includes/components/graphexplorer/visFunctions.inc.php
jomann
Development Lead
Post by jomann »
Use the above sed replace that Trevor posted for the time being. We are changing the way it does the XSS check for the next bug fix release.
BanditBBS
Post by BanditBBS »
jomann wrote:Use the above sed replace that Trevor for the time being. We are changing the way it does the XSS check for the next bug fix release.
Trevor's fix did the trick, all good now!
Well, it was the devs' fix - credit where credit is due :)
Close 'er up?
BanditBBS
Post by BanditBBS »
Yeah, feel free to close it up. I assume with this bug/fix once I check it out on dev for a few days its safe to upgrade prod and apply same fix?
