Just installed the demo XI and everything is working properly. However, whenever we access the web console, after a few clicks, we start to see a database corruption message. The console disappears and no longer works.
We do the repair, it works for another few clicks and goes corrupt again. Checking the MySQL logs, we see a similar error:Message: A database connection error has been detected, we are attempting to repair the server, if the repair does not resolve the issue, please contact Nagios support.
Run the following from the CLI as root to attempt to repair the DB
/usr/local/nagiosxi/scripts/repair_databases.sh
Any ideas what the problem might be?160405 18:28:09 [ERROR] mysqld: Table './nagios/nagios_programstatus' is marked as crashed and should be repaired
160405 18:28:09 [Warning] Checking table: './nagios/nagios_programstatus'
160405 18:28:09 [ERROR] mysqld: Table './nagios/nagios_logentries' is marked as crashed and should be repaired
160405 18:28:09 [Warning] Checking table: './nagios/nagios_logentries'
160405 18:28:09 [ERROR] mysqld: Table './nagios/nagios_systemcommands' is marked as crashed and should be repaired
160405 18:28:09 [Warning] Checking table: './nagios/nagios_systemcommands'
160405 18:28:09 [ERROR] mysqld: Table './nagios/nagios_processevents' is marked as crashed and should be repaired
160405 18:28:09 [Warning] Checking table: './nagios/nagios_processevents'
160405 18:28:09 [ERROR] mysqld: Table './nagios/nagios_configfiles' is marked as crashed and should be repaired
160405 18:28:09 [Warning] Checking table: './nagios/nagios_configfiles'
160405 18:28:09 [ERROR] mysqld: Table './nagios/nagios_configfilevariables' is marked as crashed and should be repaired
160405 18:28:09 [Warning] Checking table: './nagios/nagios_configfilevariables'
160405 18:28:09 [ERROR] mysqld: Table './nagios/nagios_commands' is marked as crashed and should be repaired
160405 18:28:09 [Warning] Checking table: './nagios/nagios_commands'
160405 18:28:09 [ERROR] mysqld: Table './nagios/nagios_timeperiods' is marked as crashed and should be repaired
160405 18:28:09 [Warning] Checking table: './nagios/nagios_timeperiods'
160405 18:28:09 [ERROR] mysqld: Table './nagios/nagios_timeperiod_timeranges' is marked as crashed and should be repaired
160405 18:28:09 [Warning] Checking table: './nagios/nagios_timeperiod_timeranges'
160405 18:28:09 [ERROR] mysqld: Table './nagios/nagios_contacts' is marked as crashed and should be repaired
160405 18:28:09 [Warning] Checking table: './nagios/nagios_contacts'
160405 18:28:09 [ERROR] mysqld: Table './nagios/nagios_contact_notificationcommands' is marked as crashed and should be repaired
160405 18:28:09 [Warning] Checking table: './nagios/nagios_contact_notificationcommands'
160405 18:28:09 [ERROR] mysqld: Table './nagios/nagios_contactgroups' is marked as crashed and should be repaired
160405 18:28:09 [Warning] Checking table: './nagios/nagios_contactgroups'
160405 18:28:09 [ERROR] mysqld: Table './nagios/nagios_contactgroup_members' is marked as crashed and should be repaired
160405 18:28:09 [Warning] Checking table: './nagios/nagios_contactgroup_members'
160405 18:28:09 [ERROR] mysqld: Table './nagios/nagios_host_contactgroups' is marked as crashed and should be repaired
160405 18:28:09 [Warning] Checking table: './nagios/nagios_host_contactgroups'
160405 18:28:09 [ERROR] mysqld: Table './nagios/nagios_service_contactgroups' is marked as crashed and should be repaired
160405 18:28:09 [Warning] Checking table: './nagios/nagios_service_contactgroups'
160405 18:28:09 [ERROR] mysqld: Table './nagios/nagios_runtimevariables' is marked as crashed and should be repaired
160405 18:28:09 [Warning] Checking table: './nagios/nagios_runtimevariables'
160405 18:28:35 [ERROR] mysqld: Table './nagios/nagios_statehistory' is marked as crashed and should be repaired
160405 18:28:35 [Warning] Checking table: './nagios/nagios_statehistory'
160405 18:30:05 mysqld_safe Number of processes running now: 0
160405 18:30:05 mysqld_safe mysqld restarted
Thanks!
