What permissions does a user need to be able to add/update the Notes tab in the Host/Status Details page.
As an admin I can update entries OK - but as a user I can only view them. Security Settings are : "User + Can access advanced features" .
I tried adding "Can control all objects" but that made no difference
regards... Fred
Acessing Notes
Fred Kroeger
Re: Acessing Notes
I tested here to find that "Can (re)configure hosts and services:" must be enabled in order for 'User' to write notes.
Page 3 of this doc gives the run-down of rights, but there is no mention of notes. I assume this omission is because Object Notes is an add-on/component.
https://assets.nagios.com/downloads/nag ... Rights.pdf
Fred Kroeger
Re: Acessing Notes
Thanks for following up.
Any chance of getting the the Notes component updated so that Users with "Access advanced features" can add info?
I really don't want to give Reconfigure access to normal users.
regards... Fred
regards... Fred
Re: Acessing Notes
I submitted a feature request for this:
NEW TASK ID 8235 created - Nagios XI Feature Request: Extend permissions for Object Notes component in XI
I agree, having the permissions set to almost wide-open seems a bit too broad just so someone can write a note, hopefully this change will be made soon.
Is there anything else we can assist with, or shall we go ahead and lock this thread?
Fred Kroeger
Re: Acessing Notes
Thanks - you can go ahead & close. Looking forward to the update!
Re: Acessing Notes
Thanks Fred! I am closing the thread now. PM me if you want to reopen it in the future.
Re: Acessing Notes
Just to be clear, a feature request does not necessarily mean this will be in the next release. It is totally up to the developers and depends on what other fixes/features they're cooking up.
