box293 vMA certificate question (for failback XI)
dlukinski
Post by dlukinski »
Hello XI support
Troy's VMWARE plugin (https://exchange.nagios.org/directory/P ... re/details) manual has steps associated with transferring certificates from XI to vMA:
This worked well for the Production XI server, now we are trying to match Production and failback configurations (make sure they got same custom plugins)
- how to transfer certificate to vMA from Failback XI (file names would be the same, something we do not want as it may override Prod certificate?
Create Certificates
Create the certificates to use with vMA
You are creating a certificate that allows the Nagios server to establish an SSH session with the
vMA without using credentials
Type
su nagios
and press Enter
(this means the following steps will be performed as the 'nagios'
user, as this is what account is used when the Nagios Monitoring Engine Executes the
box293_check_vmware pluin)
You will now be presented with: [nagios@localhost nagios-plugins-1.5]$
Type
cd ~
and press Enter
(puts you in the home directory of the nagios user)
Type
ssh-keygen -t dsa
and press Enter
Enter file in which to save the key (/home/nagios/.ssh/id_dsa):
You will use the default location so
press Enter
box293_check_vmware manual
Page
9
82
Enter passphrase (empty for no passphrase):
You will use an empty passphrase so
press Enter
Enter same passphrase again:
press Enter
A randomart image is displayed, the certificate has been created
Leave this SSH session open, you will use it in the next step
Transfer certificates to the vMA
The next command uses the IP Address or DNS name of the
vMA
(for example 192.168.1.231)
Type
cat ~/.ssh/id_dsa.pub | ssh [email protected] 'umask 077; cat
>>~/.ssh/authorized_keys'
 and press Enter
(all in one line)
An authenticity message is displayed
Are you sure you want to continue connecting (yes/no)?
Type
yes
and press Enter
You are prompted for the vi-admin password
(for example: A Str0ng P@ssw0rd)
Type
the password
and press Enter
The certificate file is transferred
Reason: Please use [code][/code] tags around long output
Re: box293 vMA certificate question (for failback XI)
You would need to create a SSH certificate on the backup machine, and transfer that to the vMA just as you did the production machine.
dlukinski
Post by dlukinski »
rkennedy wrote:You would need to create a SSH certificate on the backup machine, and transfer that to the vMA just as you did the production machine.
But it not be the same name file (overwriting previous transfer from production machine)?
You will want to append to the authorized_keys file rather then replace it the second time around. This way each server will have their own line of text to use as a SSH key.
dlukinski
Post by dlukinski »
rkennedy wrote:You will want to append to the authorized_keys file rather then replace it the second time around. This way each server will have their own line of text to use as a SSH key.
How to append?
cat ~/.ssh/id_dsa.pub from the Nagios machine, and then copy it to ~/.ssh/authorized_keys on the vma server, on a new line.
dlukinski
Post by dlukinski »
rkennedy wrote:cat ~/.ssh/id_dsa.pub from the Nagios machine, and then copy it to ~/.ssh/authorized_keys on the vma server, on a new line.
Thank you
Was able to add certificate (now know how)
Please close this support request
Sounds good, closing this out.
