Unable to start nagios - no errors
Running on RHEL 6.7 with gearmand2 the nagios web interface is telling me that the monitoring engine is not running. So I attempted to start it by clicking on the play sign and it doesn't spit out any errors. I logged on to the server
Ran this command --> service nagios status
output --> nagios is not running
Ran this command --> service nagios start
output --> Starting nagios: done.
But this is still not running. I verified the configuration and I have 3 warnings but no errors.
Warning: Service 'Memory Usage' on host 'server2' has a notification interval less than its check interval! Notifications are only re-sent after checks are made, so the effective notification interval will be that of the check interval.
Checked 258 services.
Warning: Host 'serveresg2' has no default contacts or contactgroups defined!
Warning: Host 'localhost' has no default contacts or contactgroups defined!
I ran through /var/log/messages and found no errors. Any other place I am missing where I might find an error?
Re: Unable to start nagios - no errors
How did you install gearmand2? Did you follow our documentation?
https://assets.nagios.com/downloads/nag ... ios_XI.pdf
Run the following commands and show the output in code wraps:
service gearmand restart
service nagios restart
grep gearman /usr/local/nagios/etc/nagios.cfg
grep live /usr/local/nagios/etc/nagios.cfg
ps -ef | grep [g]earman
tail /usr/local/nagios/var/nagios.log
# service gearmand restart
Stopping gearmand: [ OK ]
Starting gearmand: [ OK ]
# service nagios restart
Running configuration check...done.
Stopping nagios: /etc/init.d/nagios: line 67: kill: (14721) - No such process
done.
# grep gearman /usr/local/nagios/etc/nagios.cfg
broker_module=/usr/lib64/mod_gearman2/mod_gearman2.o config=/etc/mod_gearman2/module.conf eventhandler=no
# grep live /usr/local/nagios/etc/nagios.cfg
# ps -ef | grep [g]earman
nagios 8343 1 0 10:29 ? 00:00:00 /usr/bin/mod_gearman2_worker -d --config=/etc/mod_gearman2/worker.conf --pidfile=/var/mod_gearman2/mod_gearman_worker.pid
nagios 10849 8343 0 14:51 ? 00:00:00 /usr/bin/mod_gearman2_worker -d --config=/etc/mod_gearman2/worker.conf --pidfile=/var/mod_gearman2/mod_gearman_worker.pid
nagios 18488 8343 0 15:11 ? 00:00:00 /usr/bin/mod_gearman2_worker -d --config=/etc/mod_gearman2/worker.conf --pidfile=/var/mod_gearman2/mod_gearman_worker.pid
nagios 20967 8343 0 15:17 ? 00:00:00 /usr/bin/mod_gearman2_worker -d --config=/etc/mod_gearman2/worker.conf --pidfile=/var/mod_gearman2/mod_gearman_worker.pid
nagios 23222 8343 0 15:23 ? 00:00:00 /usr/bin/mod_gearman2_worker -d --config=/etc/mod_gearman2/worker.conf --pidfile=/var/mod_gearman2/mod_gearman_worker.pid
nagios 26630 8343 0 15:32 ? 00:00:00 /usr/bin/mod_gearman2_worker -d --config=/etc/mod_gearman2/worker.conf --pidfile=/var/mod_gearman2/mod_gearman_worker.pid
nagios 30434 8343 0 15:42 ? 00:00:00 /usr/bin/mod_gearman2_worker -d --config=/etc/mod_gearman2/worker.conf --pidfile=/var/mod_gearman2/mod_gearman_worker.pid
nagios 31081 8343 0 15:44 ? 00:00:00 /usr/bin/mod_gearman2_worker -d --config=/etc/mod_gearman2/worker.conf --pidfile=/var/mod_gearman2/mod_gearman_worker.pid
gearmand 31811 1 0 15:46 ? 00:00:00 /usr/sbin/gearmand -d --worker-wakeup=10 --retention-file=/tmp/gearmand.retention -q retention --log-file=/var/log/gearmand/gearmand.log
nagios 31999 8343 0 15:46 ? 00:00:00 /usr/bin/mod_gearman2_worker -d --config=/etc/mod_gearman2/worker.conf --pidfile=/var/mod_gearman2/mod_gearman_worker.pid
# tail /usr/local/nagios/var/nagios.log
[1460061988] ndomod registered for contact notification data'
[1460061988] ndomod registered for acknowledgement data'
[1460061988] ndomod registered for state change data'
[1460061988] ndomod registered for contact status data'
[1460061988] ndomod registered for adaptive contact data'
[1460061988] Event broker module '/usr/local/nagios/bin/ndomod.o' initialized successfully.
[1460061988] Warning: Service 'Memory Usage' on host 'server2' has a notification interval less than its check interval! Notifications are only re-sent after checks are made, so the effective notification interval will be that of the check interval.
[1460061988] Warning: Host 'server1' has no default contacts or contactgroups defined!
[1460061988] Warning: Host 'localhost' has no default contacts or contactgroups defined!
[1460061988] Successfully launched command file worker with pid 31878
done.
Does nagios start when you comment out the gearman broker module line?
You didn't tell us how you installed gearmand2. Did you follow our documentation?
# broker_module=/usr/lib64/mod_gearman2/mod_gearman2.o config=/etc/mod_gearman2/module.conf eventhandler=noCode: Select all
service nagios stop
killall nagios
service nagios startBe sure to check out our Knowledgebase for helpful articles and solutions!
I followed the nagios documentation to install it.
By the way there is another broker line in nagios.cfg:
broker_module=/usr/local/nagios/bin/ndomod.o config_file=/usr/local/nagios/etc/ndomod.cfg
Commenting the gearman broker line starts it fine.
]# service nagios start
]# service nagios status
nagios (pid 4682) is running...
Oddly enough even after uncommenting the broker line nagios comes up. I didn't see any nagios.cfg process running before. Kill all nagios process command didn't do anything.
Note that now that I have it running I am experiencing the same problem I have on another system where I am unable to submit a command command through the web.
bheden
- Product Development Manager
In /etc/mod_gearman2/module.conf AND /etc/mod_gearman2/worker.conf files can you change the line
to
Then:
Finally, can you show us the output (after performing those steps) from the following:
debug=0Code: Select all
debug=1Code: Select all
service mod-gearman2-worker restartCode: Select all
cat /usr/local/nagios/var/nagios.log | grep gearman
cat /var/log/mod_gearman2/mod_gearman_neb.log
cat /var/log/mod_gearman_worker.log
Nagios Enterprises
Senior Developer
Nagios Enterprises
Senior Developer
[1460126741] Event broker module '/usr/lib64/mod_gearman2/mod_gearman2.o' deinitialized successfully.
[1460126742] mod_gearman: initialized version 2.1.1 (libgearman 0.33)
[1460126742] Event broker module '/usr/lib64/mod_gearman2/mod_gearman2.o' initialized successfully.
[1460130362] Event broker module '/usr/lib64/mod_gearman2/mod_gearman2.o' deinitialized successfully.
[1460130363] mod_gearman: initialized version 2.1.1 (libgearman 0.33)
[1460130363] Event broker module '/usr/lib64/mod_gearman2/mod_gearman2.o' initialized successfully.
[1460130521] Event broker module '/usr/lib64/mod_gearman2/mod_gearman2.o' deinitialized successfully.
[1460130522] mod_gearman: initialized version 2.1.1 (libgearman 0.33)
[1460130522] Event broker module '/usr/lib64/mod_gearman2/mod_gearman2.o' initialized successfully.
[1460130711] Event broker module '/usr/lib64/mod_gearman2/mod_gearman2.o' deinitialized successfully.
[1460130712] mod_gearman: initialized version 2.1.1 (libgearman 0.33)
[1460130712] Event broker module '/usr/lib64/mod_gearman2/mod_gearman2.o' initialized successfully.
[1460131130] Event broker module '/usr/lib64/mod_gearman2/mod_gearman2.o' deinitialized successfully.
[1460131131] mod_gearman: initialized version 2.1.1 (libgearman 0.33)
[1460131131] Event broker module '/usr/lib64/mod_gearman2/mod_gearman2.o' initialized successfully.
Reason: Added [code][/code] tags to long output.
[2016-04-08 10:58:51][4309][DEBUG] --------------------------------
[2016-04-08 10:58:51][4309][DEBUG] configuration:
[2016-04-08 10:58:51][4309][DEBUG] log level: 1
[2016-04-08 10:58:51][4309][DEBUG] log mode: file (1)
[2016-04-08 10:58:51][4309][DEBUG] queue by cust var: no
[2016-04-08 10:58:51][4309][DEBUG] debug result: no
[2016-04-08 10:58:51][4309][DEBUG] result_worker: 1
[2016-04-08 10:58:51][4309][DEBUG] do_hostchecks: yes
[2016-04-08 10:58:51][4309][DEBUG] route_eventhandler_like_checks: no
[2016-04-08 10:58:51][4309][DEBUG] result_queue: check_results
[2016-04-08 10:58:51][4309][DEBUG] server: localhost:4730
[2016-04-08 10:58:51][4309][DEBUG] perfdata: no
[2016-04-08 10:58:51][4309][DEBUG] perfdata mode: overwrite
[2016-04-08 10:58:51][4309][DEBUG] hosts: yes
[2016-04-08 10:58:51][4309][DEBUG] services: yes
[2016-04-08 10:58:51][4309][DEBUG] eventhandler: no
[2016-04-08 10:58:51][4309][DEBUG] encryption: yes
[2016-04-08 10:58:51][4309][DEBUG] keyfile: no
[2016-04-08 10:58:51][4309][DEBUG] encryption key: set
[2016-04-08 10:58:51][4309][DEBUG] accept clear result: no
[2016-04-08 10:58:51][4309][DEBUG] transport mode: aes-256+base64
[2016-04-08 10:58:51][4309][DEBUG] use uniq jobs: yes
[2016-04-08 10:58:51][4309][DEBUG] finished initializing
[2016-04-08 10:58:51][4309][DEBUG] registered neb callbacks
after 10:58 it looks the same as below.
[2016-04-08 11:06:05][6125][DEBUG] received job for queue service: test9x5server - CPU Load
[2016-04-08 11:06:05][6125][DEBUG] service: 'test9x5server' - 'CPU Load', next_check is at 2016-04-08 11:06:05, latency so far: 0
[2016-04-08 11:06:05][6125][DEBUG] service job completed: test9x5server CPU Load: 2
[2016-04-08 11:06:06][6125][DEBUG] received job for queue service: nrpe9x5checkperiod - Total Processes
[2016-04-08 11:06:06][6125][DEBUG] service: 'nrpe9x5checkperiod' - 'Total Processes', next_check is at 2016-04-08 11:06:06, latency so far: 0
[2016-04-08 11:06:06][6125][DEBUG] service job completed: nrpe9x5checkperiod Total Processes: 1
[2016-04-08 11:06:07][6125][DEBUG] received job for queue service: server44- Uptime
[2016-04-08 11:06:07][6125][DEBUG] service: server55- 'Uptime', next_check is at 2016-04-08 11:06:07, latency so far: 0
[2016-04-08 11:06:07][6125][DEBUG] service job completed: server44Uptime: 0
[2016-04-08 11:06:08][6125][DEBUG] received job for queue service: server33 - DNS IP Match
[2016-04-08 11:06:08][6125][DEBUG] service: 'server33' - 'DNS IP Match', next_check is at 2016-04-08 11:06:08, latency so far: 0
[2016-04-08 11:06:08][6125][DEBUG] service job completed: server33 DNS IP Match: 0
[2016-04-08 11:06:09][6125][DEBUG] received job for queue service: server44- MountPoint - M:Star_ReportLog
[2016-04-08 11:06:09][6125][DEBUG] service: server55- 'MountPoint - M:Star_ReportLog', next_check is at 2016-04-08 11:06:09, latency so far: 0
[2016-04-08 11:06:09][6125][DEBUG] service job completed: server44MountPoint - M:Star_ReportLog: 0
[2016-04-08 11:06:10][6125][DEBUG] received job for queue service: server2 - Exchange_RPC_User_Count
[2016-04-08 11:06:10][6125][DEBUG] service: 'server2' - 'Exchange_RPC_User_Count', next_check is at 2016-04-08 11:06:10, latency so far: 0
[2016-04-08 11:06:10][6125][DEBUG] service job completed: server2 Exchange_RPC_User_Count: 3
[2016-04-08 11:06:11][6125][DEBUG] received job for queue service: test2 - Current Load
[2016-04-08 11:06:11][6125][DEBUG] service: 'test2' - 'Current Load', next_check is at 2016-04-08 11:06:11, latency so far: 0
[2016-04-08 11:06:11][6125][DEBUG] service job completed: test2 Current Load: 2
[2016-04-08 11:06:12][6125][DEBUG] received job for queue service: hamster - Eventlog
[2016-04-08 11:06:12][6125][DEBUG] service: 'hamster' - 'Eventlog', next_check is at 2016-04-08 11:06:12, latency so far: 0
[2016-04-08 11:06:12][6125][DEBUG] service job completed: hamster Eventlog: 0
[2016-04-08 11:06:13][6125][DEBUG] received job for queue service: test4 - Current Users
[2016-04-08 11:06:13][6125][DEBUG] service: 'test4' - 'Current Users', next_check is at 2016-04-08 11:06:13, latency so far: 0
[2016-04-08 11:06:14][6125][DEBUG] received job for queue service: test66 - CPU Load
[2016-04-08 11:06:14][6125][DEBUG] service: 'test66' - 'CPU Load', next_check is at 2016-04-08 11:06:14, latency so far: 0
[2016-04-08 11:06:14][6125][DEBUG] service job completed: test66 CPU Load: 0
[2016-04-08 11:06:14][6125][DEBUG] received job for queue host: server2
[2016-04-08 11:06:14][6125][DEBUG] host: 'server2', next_check is at 2016-04-08 11:06:14, latency so far: 0
[2016-04-08 11:06:14][6125][DEBUG] received job for queue host: nrpe9x5checkperiod
[2016-04-08 11:06:14][6125][DEBUG] host: 'nrpe9x5checkperiod', next_check is at 2016-04-08 11:06:14, latency so far: 0
[2016-04-08 11:06:14][6125][DEBUG] received job for queue host: test9x5server
[2016-04-08 11:06:14][6125][DEBUG] host: 'test9x5server', next_check is at 2016-04-08 11:06:14, latency so far: 0
[2016-04-08 11:06:14][6125][DEBUG] host job completed: test9x5server: 3
[2016-04-08 11:06:14][6125][DEBUG] host job completed: server2: 0
[2016-04-08 11:06:15][6125][DEBUG] host job completed: nrpe9x5checkperiod: 3
[2016-04-08 11:06:15][6125][DEBUG] received job for queue service: nrpe9x5checkperiod - File System Space
[2016-04-08 11:06:15][6125][DEBUG] service: 'nrpe9x5checkperiod' - 'File System Space', next_check is at 2016-04-08 11:06:15, latency so far: 0
[2016-04-08 11:06:16][6125][DEBUG] service job completed: nrpe9x5checkperiod File System Space: 1
[2016-04-08 11:06:16][6125][DEBUG] service job completed: test4 Current Users: 2
[2016-04-08 11:06:16][6125][DEBUG] received job for queue service: server2 - Exchange Connection Count
[2016-04-08 11:06:16][6125][DEBUG] service: 'server2' - 'Exchange Connection Count', next_check is at 2016-04-08 11:06:16, latency so far: 0
[2016-04-08 11:06:17][6125][DEBUG] service job completed: server2 Exchange Connection Count: 3
[2016-04-08 11:06:17][6125][DEBUG] received job for queue service: localhost - ExternalCommandsUsed 1mn
[2016-04-08 11:06:17][6125][DEBUG] service: 'localhost' - 'ExternalCommandsUsed 1mn', next_check is at 2016-04-08 11:06:18, latency so far: -1
[2016-04-08 11:06:18][6125][DEBUG] service job completed: localhost ExternalCommandsUsed 1mn: 0
[2016-04-08 11:06:19][6125][DEBUG] received job for queue service: ARCHITECT - Ping
[2016-04-08 11:06:19][6125][DEBUG] service: 'ARCHITECT' - 'Ping', next_check is at 2016-04-08 11:06:19, latency so far: 0
[2016-04-08 11:06:20][6125][DEBUG] received job for queue service: server2 - Active_Virtual_Memory_in_MB
[2016-04-08 11:06:20][6125][DEBUG] service: 'server2' - 'Active_Virtual_Memory_in_MB', next_check is at 2016-04-08 11:06:20, latency so far: 0
[2016-04-08 11:06:20][6125][DEBUG] service job completed: server2 Active_Virtual_Memory_in_MB: 0
[2016-04-08 11:06:21][6125][DEBUG] received job for queue service: server44- IIS World Wide Web Publishing Service
[2016-04-08 11:06:21][6125][DEBUG] service: server55- 'IIS World Wide Web Publishing Service', next_check is at 2016-04-08 11:06:21, latency so far: 0
[2016-04-08 11:06:21][6125][DEBUG] service job completed: server44IIS World Wide Web Publishing Service: 3
[2016-04-08 11:06:22][6125][DEBUG] received job for queue service: AliasLongFixingTester - Current Load
[2016-04-08 11:06:22][6125][DEBUG] service: 'AliasLongFixingTester' - 'Current Load', next_check is at 2016-04-08 11:06:22, latency so far: 0
[2016-04-08 11:06:22][6125][DEBUG] service job completed: AliasLongFixingTester Current Load: 1
[2016-04-08 11:06:23][6125][DEBUG] received job for queue service: server44- Memory Usage
[2016-04-08 11:06:23][6125][DEBUG] service: server55- 'Memory Usage', next_check is at 2016-04-08 11:06:23, latency so far: 0
[2016-04-08 11:06:23][6125][DEBUG] service job completed: server44Memory Usage: 0
[2016-04-08 11:06:24][6125][DEBUG] received job for queue host: AliasLongFixingTester
[2016-04-08 11:06:24][6125][DEBUG] host: 'AliasLongFixingTester', next_check is at 2016-04-08 11:06:24, latency so far: 0
[2016-04-08 11:06:24][6125][DEBUG] received job for queue host: test88
[2016-04-08 11:06:24][6125][DEBUG] host: 'test88', next_check is at 2016-04-08 11:06:24, latency so far: 0
[2016-04-08 11:06:24][6125][DEBUG] received job for queue host: test4
[2016-04-08 11:06:24][6125][DEBUG] host: 'test4', next_check is at 2016-04-08 11:06:24, latency so far: 0
[2016-04-08 11:06:24][6125][DEBUG] host job completed: test88: 0
[2016-04-08 11:06:24][6125][DEBUG] received job for queue host: test99
[2016-04-08 11:06:24][6125][DEBUG] host: 'test99', next_check is at 2016-04-08 11:06:24, latency so far: 0
[2016-04-08 11:06:25][6125][DEBUG] host job completed: AliasLongFixingTester: 3
[2016-04-08 11:06:25][6125][DEBUG] received job for queue service: server2 - Memory Usage
[2016-04-08 11:06:25][6125][DEBUG] service: 'server2' - 'Memory Usage', next_check is at 2016-04-08 11:06:25, latency so far: 0
[2016-04-08 11:06:25][6125][DEBUG] service job completed: server2 Memory Usage: 0
[2016-04-08 11:06:26][6125][DEBUG] received job for queue service: test2 - Current Users
[2016-04-08 11:06:26][6125][DEBUG] service: 'test2' - 'Current Users', next_check is at 2016-04-08 11:06:26, latency so far: 0
[2016-04-08 11:06:26][6125][DEBUG] service job completed: test2 Current Users: 2
[2016-04-08 11:06:27][6125][DEBUG] received job for queue service: server44- Disk - C
[2016-04-08 11:06:27][6125][DEBUG] service: server55- 'Disk - C', next_check is at 2016-04-08 11:06:27, latency so far: 0
[2016-04-08 11:06:27][6125][DEBUG] service job completed: server44Disk - C: 0
[2016-04-08 11:06:27][6125][DEBUG] host job completed: test4: 2
[2016-04-08 11:06:28][6125][DEBUG] received job for queue service: server2 - RPC_HTTP_Connection_Count
[2016-04-08 11:06:28][6125][DEBUG] service: 'server2' - 'RPC_HTTP_Connection_Count', next_check is at 2016-04-08 11:06:28, latency so far: 0
[2016-04-08 11:06:28][6125][DEBUG] service job completed: server2 RPC_HTTP_Connection_Count: 3
[2016-04-08 11:06:29][6125][DEBUG] service job completed: ARCHITECT Ping: 2
[2016-04-08 11:06:29][6125][DEBUG] received job for queue service: localhost - ActiveHostChecks 1mn
[2016-04-08 11:06:29][6125][DEBUG] service: 'localhost' - 'ActiveHostChecks 1mn', next_check is at 2016-04-08 11:06:29, latency so far: 0
[2016-04-08 11:06:29][6125][DEBUG] service job completed: localhost ActiveHostChecks 1mn: 0
[2016-04-08 11:06:30][6125][DEBUG] received job for queue service: nrpe9x5checkperiod - Swap
[2016-04-08 11:06:30][6125][DEBUG] service: 'nrpe9x5checkperiod' - 'Swap', next_check is at 2016-04-08 11:06:30, latency so far: 0
[2016-04-08 11:06:30][6125][DEBUG] service job completed: nrpe9x5checkperiod Swap: 1
[2016-04-08 11:06:31][6125][DEBUG] received job for queue service: nrpe9x5checkperiod - Current Load
[2016-04-08 11:06:31][6125][DEBUG] service: 'nrpe9x5checkperiod' - 'Current Load', next_check is at 2016-04-08 11:06:31, latency so far: 0
[2016-04-08 11:06:31][6125][DEBUG] service job completed: nrpe9x5checkperiod Current Load: 1
[2016-04-08 11:06:32][6125][DEBUG] received job for queue service: localhost - ActiveServiceChecks 1mn
[2016-04-08 11:06:32][6125][DEBUG] service: 'localhost' - 'ActiveServiceChecks 1mn', next_check is at 2016-04-08 11:06:32, latency so far: 0
[2016-04-08 11:06:32][6125][DEBUG] service job completed: localhost ActiveServiceChecks 1mn: 0
[2016-04-08 11:06:33][6125][DEBUG] received job for queue service: nagiosxi - Current Load
[2016-04-08 11:06:33][6125][DEBUG] service: 'nagiosxi' - 'Current Load', next_check is at 2016-04-08 11:06:33, latency so far: 0
[2016-04-08 11:06:33][6125][DEBUG] service job completed: nagiosxi Current Load: 2
[2016-04-08 11:06:34][6125][DEBUG] received job for queue service: localhost - PassiveHostChecks 1mn
[2016-04-08 11:06:34][6125][DEBUG] service: 'localhost' - 'PassiveHostChecks 1mn', next_check is at 2016-04-08 11:06:34, latency so far: 0
[2016-04-08 11:06:34][6125][DEBUG] service job completed: localhost PassiveHostChecks 1mn: 0
[2016-04-08 11:06:34][6125][DEBUG] received job for queue host: nagiosxi
[2016-04-08 11:06:34][6125][DEBUG] host: 'nagiosxi', next_check is at 2016-04-08 11:06:34, latency so far: 0
[2016-04-08 11:06:34][6125][DEBUG] received job for queue host: nrpe9x5checkperiod
[2016-04-08 11:06:34][6125][DEBUG] host: 'nrpe9x5checkperiod', next_check is at 2016-04-08 11:06:34, latency so far: 0
[2016-04-08 11:06:34][6125][DEBUG] received job for queue host: ARCHITECT
[2016-04-08 11:06:34][6125][DEBUG] host: 'ARCHITECT', next_check is at 2016-04-08 11:06:34, latency so far: 0
[2016-04-08 11:06:34][6125][DEBUG] received job for queue host: server2
[2016-04-08 11:06:34][6125][DEBUG] host: 'server2', next_check is at 2016-04-08 11:06:34, latency so far: 0
[2016-04-08 11:06:34][6125][DEBUG] received job for queue host: test2
[2016-04-08 11:06:34][6125][DEBUG] host: 'test2', next_check is at 2016-04-08 11:06:34, latency so far: 0
[2016-04-08 11:06:34][6125][DEBUG] host job completed: nagiosxi: 0
[2016-04-08 11:06:34][6125][DEBUG] host job completed: test2: 0
[2016-04-08 11:06:34][6125][DEBUG] host job completed: server2: 0
[2016-04-08 11:06:35][6125][DEBUG] host job completed: test99: 2
[2016-04-08 11:06:35][6125][DEBUG] host job completed: nrpe9x5checkperiod: 3
[2016-04-08 11:06:35][6125][DEBUG] received job for queue service: server44- Eventlog
[2016-04-08 11:06:35][6125][DEBUG] service: server55- 'Eventlog', next_check is at 2016-04-08 11:06:35, latency so far: 0
[2016-04-08 11:06:35][6125][DEBUG] service job completed: server44Eventlog: 0
[2016-04-08 11:06:36][6125][DEBUG] received job for queue service: test99 - Uptime
[2016-04-08 11:06:36][6125][DEBUG] service: 'test99' - 'Uptime', next_check is at 2016-04-08 11:06:36, latency so far: 0
[2016-04-08 11:06:37][6125][DEBUG] received job for queue service: serverrr - Current Load
[2016-04-08 11:06:37][6125][DEBUG] service: 'serverrr' - 'Current Load', next_check is at 2016-04-08 11:06:37, latency so far: 0
[2016-04-08 11:06:37][6125][DEBUG] service job completed: serverrr Current Load: 0
[2016-04-08 11:06:38][6125][DEBUG] received job for queue service: localhost - PassiveServiceChecks 1mn
[2016-04-08 11:06:38][6125][DEBUG] service: 'localhost' - 'PassiveServiceChecks 1mn', next_check is at 2016-04-08 11:06:38, latency so far: 0
[2016-04-08 11:06:38][6125][DEBUG] service job completed: localhost PassiveServiceChecks 1mn: 0
[2016-04-08 11:06:39][6125][DEBUG] received job for queue service: nagiosxi - Current Users
[2016-04-08 11:06:39][6125][DEBUG] service: 'nagiosxi' - 'Current Users', next_check is at 2016-04-08 11:06:39, latency so far: 0
[2016-04-08 11:06:39][6125][DEBUG] service job completed: nagiosxi Current Users: 2
[2016-04-08 11:06:40][6125][DEBUG] received job for queue host: test66
[2016-04-08 11:06:40][6125][DEBUG] host: 'test66', next_check is at 2016-04-08 11:06:40, latency so far: 0
[2016-04-08 11:06:40][6125][DEBUG] host job completed: test66: 0
[2016-04-08 11:06:41][6125][DEBUG] received job for queue service: hamster - Ping
[2016-04-08 11:06:41][6125][DEBUG] service: 'hamster' - 'Ping', next_check is at 2016-04-08 11:06:41, latency so far: 0
[2016-04-08 11:06:41][6125][DEBUG] service job completed: hamster Ping: 0
[2016-04-08 11:06:42][6125][DEBUG] received job for queue service: nrpe9x5checkperiod - Ping
[2016-04-08 11:06:42][6125][DEBUG] service: 'nrpe9x5checkperiod' - 'Ping', next_check is at 2016-04-08 11:06:42, latency so far: 0
[2016-04-08 11:06:43][6125][DEBUG] service job completed: nrpe9x5checkperiod Ping: 3
[2016-04-08 11:06:43][6125][DEBUG] received job for queue service: test99 - Memory Usage
[2016-04-08 11:06:43][6125][DEBUG] service: 'test99' - 'Memory Usage', next_check is at 2016-04-08 11:06:43, latency so far: 0
[2016-04-08 11:06:44][6125][DEBUG] received job for queue service: dragon - CPU Load
[2016-04-08 11:06:44][6125][DEBUG] service: 'dragon' - 'CPU Load', next_check is at 2016-04-08 11:06:44, latency so far: 0
[2016-04-08 11:06:44][6125][DEBUG] host job completed: ARCHITECT: 2
[2016-04-08 11:06:45][6125][DEBUG] received job for queue service: testchanger- Processor_Timing
[2016-04-08 11:06:45][6125][DEBUG] service: 'testchanger' - 'Processor_Timing', next_check is at 2016-04-08 11:06:45, latency so far: 0
[2016-04-08 11:06:46][6125][DEBUG] service job completed: test99 Uptime: 2
[2016-04-08 11:06:46][6125][DEBUG] received job for queue service: server44- SQL Server Agent
[2016-04-08 11:06:46][6125][DEBUG] service: server55- 'SQL Server Agent', next_check is at 2016-04-08 11:06:47, latency so far: -1
[2016-04-08 11:06:46][6125][DEBUG] service job completed: testchangerProcessor_Timing: 0
[2016-04-08 11:06:46][6125][DEBUG] service job completed: server44SQL Server Agent: 0
[2016-04-08 11:06:48][6125][DEBUG] received job for queue service: hamster - Check log3
[2016-04-08 11:06:48][6125][DEBUG] service: 'hamster' - 'Check log3', next_check is at 2016-04-08 11:06:48, latency so far: 0
[2016-04-08 11:06:48][6125][DEBUG] service job completed: hamster Check log3: 2
[2016-04-08 11:06:49][6125][DEBUG] received job for queue service: serverrr - Swap
[2016-04-08 11:06:49][6125][DEBUG] service: 'serverrr' - 'Swap', next_check is at 2016-04-08 11:06:49, latency so far: 0
[2016-04-08 11:06:49][6125][DEBUG] service job completed: serverrr Swap: 0
[2016-04-08 11:06:50][6125][DEBUG] received job for queue service: hamster - Memory Physical RAM Usage
[2016-04-08 11:06:50][6125][DEBUG] service: 'hamster' - 'Memory Physical RAM Usage', next_check is at 2016-04-08 11:06:50, latency so far: 0
[2016-04-08 11:06:50][6125][DEBUG] service job completed: hamster Memory Physical RAM Usage: 0
[2016-04-08 11:06:51][6125][DEBUG] received job for queue service: server2 - HTTP_PROXY_Unique_Users
[2016-04-08 11:06:51][6125][DEBUG] service: 'server2' - 'HTTP_PROXY_Unique_Users', next_check is at 2016-04-08 11:06:51, latency so far: 0
[2016-04-08 11:06:51][6125][DEBUG] service job completed: server2 HTTP_PROXY_Unique_Users: 3
[2016-04-08 11:06:53][6125][DEBUG] received job for queue service: test2 - Ping
[2016-04-08 11:06:53][6125][DEBUG] service: 'test2' - 'Ping', next_check is at 2016-04-08 11:06:53, latency so far: 0
[2016-04-08 11:06:53][6125][DEBUG] service job completed: test2 Ping: 0
[2016-04-08 11:06:53][6125][DEBUG] service job completed: test99 Memory Usage: 2
[2016-04-08 11:06:54][6125][DEBUG] received job for queue service: test66 - Disk - C
[2016-04-08 11:06:54][6125][DEBUG] service: 'test66' - 'Disk - C', next_check is at 2016-04-08 11:06:54, latency so far: 0
[2016-04-08 11:06:54][6125][DEBUG] service job completed: test66 Disk - C: 0
[2016-04-08 11:06:54][6125][DEBUG] service job completed: dragon CPU Load: 2
[2016-04-08 11:06:54][6125][DEBUG] received job for queue service: testchanger- HTTP_PROXY_Unique_Users
[2016-04-08 11:06:54][6125][DEBUG] service: 'testchanger' - 'HTTP_PROXY_Unique_Users', next_check is at 2016-04-08 11:06:54, latency so far: 0
[2016-04-08 11:06:54][6125][DEBUG] received job for queue host: dragon
[2016-04-08 11:06:54][6125][DEBUG] host: 'dragon', next_check is at 2016-04-08 11:06:54, latency so far: 0
[2016-04-08 11:06:54][6125][DEBUG] received job for queue host: test99
[2016-04-08 11:06:54][6125][DEBUG] host: 'test99', next_check is at 2016-04-08 11:06:54, latency so far: 0
[2016-04-08 11:06:54][6125][DEBUG] received job for queue host: server2
[2016-04-08 11:06:54][6125][DEBUG] host: 'server2', next_check is at 2016-04-08 11:06:54, latency so far: 0
[2016-04-08 11:06:54][6125][DEBUG] received job for queue host: hamster
[2016-04-08 11:06:54][6125][DEBUG] host: 'hamster', next_check is at 2016-04-08 11:06:54, latency so far: 0
[2016-04-08 11:06:54][6125][DEBUG] host job completed: dragon: 0
[2016-04-08 11:06:54][6125][DEBUG] service job completed: testchangerHTTP_PROXY_Unique_Users: 0
[2016-04-08 11:06:55][6125][DEBUG] host job completed: server2: 0
[2016-04-08 11:06:55][6125][DEBUG] host job completed: hamster: 0
[2016-04-08 11:06:55][6125][DEBUG] received job for queue service: sharechanger- Multi Address Ping
[2016-04-08 11:06:55][6125][DEBUG] service: 'sharechanger' - 'Multi Address Ping', next_check is at 2016-04-08 11:06:55, latency so far: 0
[2016-04-08 11:06:56][6125][DEBUG] received job for queue service: nagiosxi - Total Processes
[2016-04-08 11:06:56][6125][DEBUG] service: 'nagiosxi' - 'Total Processes', next_check is at 2016-04-08 11:06:56, latency so far: 0
[2016-04-08 11:06:56][6125][DEBUG] service job completed: nagiosxi Total Processes: 2
[2016-04-08 11:06:57][6125][DEBUG] received job for queue service: test9x5server - Ping
[2016-04-08 11:06:57][6125][DEBUG] service: 'test9x5server' - 'Ping', next_check is at 2016-04-08 11:06:57, latency so far: 0
[2016-04-08 11:06:57][6125][DEBUG] service job completed: test9x5server Ping: 3
[2016-04-08 11:06:58][6125][DEBUG] received job for queue service: server2 - Uptime
[2016-04-08 11:06:58][6125][DEBUG] service: 'server2' - 'Uptime', next_check is at 2016-04-08 11:06:58, latency so far: 0
[2016-04-08 11:06:58][6125][DEBUG] service job completed: server2 Uptime: 0
[2016-04-08 11:06:59][6125][DEBUG] received job for queue service: hamster - Disk - C
[2016-04-08 11:06:59][6125][DEBUG] service: 'hamster' - 'Disk - C', next_check is at 2016-04-08 11:06:59, latency so far: 0
[2016-04-08 11:06:59][6125][DEBUG] service job completed: hamster Disk - C: 0
[2016-04-08 11:07:00][6125][DEBUG] received job for queue service: serverrr - Total Processes
[2016-04-08 11:07:00][6125][DEBUG] service: 'serverrr' - 'Total Processes', next_check is at 2016-04-08 11:07:00, latency so far: 0
[2016-04-08 11:07:00][6125][DEBUG] service job completed: serverrr Total Processes: 0
[2016-04-08 11:07:01][6125][DEBUG] received job for queue service: test2 - Total Processes
[2016-04-08 11:07:01][6125][DEBUG] service: 'test2' - 'Total Processes', next_check is at 2016-04-08 11:07:01, latency so far: 0
[2016-04-08 11:07:01][6125][DEBUG] service job completed: test2 Total Processes: 2
[2016-04-08 11:07:01][6125][DEBUG] service job completed: sharechangerMulti Address Ping: 0
[2016-04-08 11:07:02][6125][DEBUG] received job for queue service: testchanger- Exchange_RPC_Average_Latency
[2016-04-08 11:07:02][6125][DEBUG] service: 'testchanger' - 'Exchange_RPC_Average_Latency', next_check is at 2016-04-08 11:07:02, latency so far: 0
[2016-04-08 11:07:02][6125][DEBUG] service job completed: testchangerExchange_RPC_Average_Latency: 0
cat /var/log/mod_gearman2/mod_gearman_worker.log | grep 2016-04-08
[2016-04-08 10:58:51][12318][ERROR] worker error: flush(Broken pipe) lost connection to server during send -> libgearman/connection.cc:761
[2016-04-08 10:59:01][8343][INFO ] mod_gearman worker exited
[2016-04-08 10:59:02][4515][DEBUG] --------------------------------
[2016-04-08 10:59:02][4515][DEBUG] configuration:
[2016-04-08 10:59:02][4515][DEBUG] log level: 1
[2016-04-08 10:59:02][4515][DEBUG] log mode: file (1)
[2016-04-08 10:59:02][4515][DEBUG] identifier: <NAGIOSTESTHOSTFQDN>
[2016-04-08 10:59:02][4515][DEBUG] pidfile: /var/mod_gearman2/mod_gearman_worker.pid
[2016-04-08 10:59:02][4515][DEBUG] logfile: /var/log/mod_gearman2/mod_gearman_worker.log
[2016-04-08 10:59:02][4515][DEBUG] job max num: 1000
[2016-04-08 10:59:02][4515][DEBUG] job max age: 0
[2016-04-08 10:59:02][4515][DEBUG] job timeout: 60
[2016-04-08 10:59:02][4515][DEBUG] min worker: 5
[2016-04-08 10:59:02][4515][DEBUG] max worker: 50
[2016-04-08 10:59:02][4515][DEBUG] spawn rate: 1
[2016-04-08 10:59:02][4515][DEBUG] fork on exec: no
[2016-04-08 10:59:02][4515][DEBUG] embedded perl: yes
[2016-04-08 10:59:02][4515][DEBUG] use_epn_implicitly: no
[2016-04-08 10:59:02][4515][DEBUG] use_perl_cache: yes
[2016-04-08 10:59:02][4515][DEBUG] p1_file: /usr/share/mod_gearman2/mod_gearman_p1.pl
[2016-04-08 10:59:02][4515][DEBUG] server: localhost:4730
[2016-04-08 10:59:02][4515][DEBUG] hosts: yes
[2016-04-08 10:59:02][4515][DEBUG] services: yes
[2016-04-08 10:59:02][4515][DEBUG] eventhandler: yes
[2016-04-08 10:59:02][4515][DEBUG] encryption: yes
[2016-04-08 10:59:02][4515][DEBUG] keyfile: no
[2016-04-08 10:59:02][4515][DEBUG] encryption key: set
[2016-04-08 10:59:02][4515][DEBUG] transport mode: aes-256+base64
[2016-04-08 10:59:02][4515][DEBUG] use uniq jobs: yes
[2016-04-08 10:59:02][4534][INFO ] mod_gearman worker daemon started with pid 4534
[2016-04-08 10:59:02][4534][DEBUG] Version 2.1.1
[2016-04-08 10:59:02][4534][DEBUG] running on libgearman 0.33
[2016-04-08 10:59:02][4534][DEBUG] pid file /var/mod_gearman2/mod_gearman_worker.pid written
[2016-04-08 10:59:02][4534][DEBUG] main process started
[2016-04-08 10:59:02][4539][DEBUG] child started with pid: 4539
[2016-04-08 10:59:02][4538][DEBUG] child started with pid: 4538
[2016-04-08 10:59:02][4540][DEBUG] child started with pid: 4540
[2016-04-08 10:59:02][4537][DEBUG] child started with pid: 4537
[2016-04-08 10:59:02][4536][DEBUG] child started with pid: 4536
[2016-04-08 10:59:02][4535][DEBUG] child started with pid: 4535
[2016-04-08 10:59:03][4538][DEBUG] got service job: citrixtest9x5period - Citrix Services Manager Service
[2016-04-08 10:59:04][4540][DEBUG] got service job: sharechanger - Eventlog
[2016-04-08 10:59:05][4537][DEBUG] got service job: sharechanger - Uptime
[2016-04-08 10:59:07][4536][DEBUG] got service job: appstuff - Current Users
[2016-04-08 10:59:07][4539][DEBUG] got service job: localhost - ActiveServiceChecks 1mn
[2016-04-08 10:59:08][4540][DEBUG] got service job: sharechanger - Ping
[2016-04-08 10:59:10][4538][DEBUG] got service job: dragon - Disk - C
[2016-04-08 10:59:11][4536][DEBUG] got service job: shareinfinite- Disk - C
[2016-04-08 10:59:12][4537][DEBUG] got service job: citrixtest9x5period - Citrix Independent Management Architecture Service
[2016-04-08 10:59:14][4539][DEBUG] got service job: shareinfinite- CPU Load
[2016-04-08 10:59:15][4540][DEBUG] got service job: exchangeserver - Exchange_RPC_User_Count
[2016-04-08 10:59:16][4537][DEBUG] got service job: nagiosxihost - File System Space
[2016-04-08 10:59:17][4540][DEBUG] got service job: citrixtest9x5period - Citrix Group Policy Engine
[2016-04-08 10:59:19][4537][DEBUG] got service job: citrixtest9x5period - Citrix XTE Server
[2016-04-08 10:59:20][4539][DEBUG] got service job: appstuff - File System Space
[2016-04-08 10:59:20][4539][DEBUG] got host job: citrixtest9x5period
[2016-04-08 10:59:20][4536][DEBUG] got host job: nagiosxihost
[2016-04-08 10:59:21][4538][DEBUG] got service job: dragon - Memory Usage
[2016-04-08 10:59:22][4540][DEBUG] got service job: exchangeserver22 - Exchange_Pending_Ping_Count
[2016-04-08 10:59:22][4536][DEBUG] got service job: appstuff - check_log3_kpi_SQL
[2016-04-08 10:59:23][4537][DEBUG] got service job: citrixtest9x5period - Citrix MFCOM Service
[2016-04-08 10:59:25][4537][DEBUG] got service job: hamster - CPU Usage Counter
[2016-04-08 10:59:26][4540][DEBUG] got service job: exchangeserver - Active_Virtual_Memory_in_MB
[2016-04-08 10:59:27][4537][DEBUG] got service job: nagiosxihost - SSH
[2016-04-08 10:59:27][4540][DEBUG] got service job: exchangeserver - Exchange_RPC_Connection_Count
[2016-04-08 10:59:29][4537][DEBUG] got service job: hamster - CPU Load NRPE 80 180 1440
[2016-04-08 10:59:30][4540][DEBUG] got service job: exchangeserver22 - CPU Load
[2016-04-08 10:59:30][4540][DEBUG] got host job: exchangeserver
[2016-04-08 10:59:31][4537][DEBUG] got service job: server777 - Disk - M
[2016-04-08 10:59:32][4537][DEBUG] got service job: localhost - ExternalCommandsUsed 1mn
[2016-04-08 10:59:33][4679][DEBUG] child started with pid: 4679
[2016-04-08 10:59:34][4537][DEBUG] got service job: hamster - CPU Load
[2016-04-08 10:59:35][4540][DEBUG] got service job: AliasLongFixingTester - Current Load
[2016-04-08 10:59:36][4536][DEBUG] got service job: exchangeserver22 - Exchange_RPC_Connection_Count
[2016-04-08 10:59:37][4538][DEBUG] got service job: localhost - ActiveHostChecks 1mn
[2016-04-08 10:59:37][4538][DEBUG] got service job: dragon - Uptime
[2016-04-08 10:59:38][4537][DEBUG] got service job: nagiosxihost - Swap
[2016-04-08 10:59:39][4536][DEBUG] got service job: ping9x5check_period - Ping
[2016-04-08 10:59:40][4539][DEBUG] got host job: fakeserver
[2016-04-08 10:59:40][4536][DEBUG] got host job: ping9x5check_period
[2016-04-08 10:59:40][4540][DEBUG] got host job: nagiosxihost
[2016-04-08 10:59:40][4537][DEBUG] got host job: AliasLongFixingTester
[2016-04-08 10:59:41][4540][DEBUG] got service job: nrpe9x5checkperiod - Current Users
[2016-04-08 10:59:42][4536][DEBUG] got service job: citrixtest9x5period - Ping
[2016-04-08 10:59:42][4539][DEBUG] got service job: localhost - PassiveHostChecks 1mn
[2016-04-08 10:59:43][4537][DEBUG] got service job: someserver999- File System Space
[2016-04-08 10:59:43][4537][DEBUG] check exited with exit code > 3. Exit: 255
[2016-04-08 10:59:43][4537][DEBUG] stdout:
[2016-04-08 10:59:45][4537][DEBUG] got service job: nagiosxihost - Ping
[2016-04-08 10:59:46][4539][DEBUG] got service job: nrpe9x5checkperiod - SSH
[2016-04-08 10:59:47][4539][DEBUG] got service job: hamster - CPU Load NRPE
[2016-04-08 10:59:47][4536][DEBUG] got service job: citrixtest9x5period - Remote Desktop Services
[2016-04-08 10:59:48][4540][DEBUG] got service job: hamster - Uptime
[2016-04-08 10:59:49][4539][DEBUG] got service job: printer9x5checks - Ping
[2016-04-08 10:59:50][4537][DEBUG] got service job: windows9x5check_period - Uptime
[2016-04-08 10:59:50][4538][DEBUG] got service job: dragon - Ping
[2016-04-08 10:59:50][4540][DEBUG] got service job: <SOMEIP>- CPU Usage for VMHost
[2016-04-08 10:59:50][4540][DEBUG] Using Embedded Perl interpreter for: /usr/local/nagios/libexec/check_esx3.pl
[2016-04-08 10:59:50][4539][DEBUG] got service job: <SOMEIP>- Datastore usage for VMHost
[2016-04-08 10:59:50][4539][DEBUG] Using Embedded Perl interpreter for: /usr/local/nagios/libexec/check_esx3.pl
[2016-04-08 10:59:50][4536][DEBUG] got service job: <SOMEIP>- Networking for VMHost
[2016-04-08 10:59:50][4536][DEBUG] Using Embedded Perl interpreter for: /usr/local/nagios/libexec/check_esx3.pl
[2016-04-08 10:59:51][4537][DEBUG] got service job: SQLSERVER - MSSQL Buffer Hit Ratio
[2016-04-08 10:59:51][4538][DEBUG] got service job: SQLSERVER - MSSQL Checkpoint Pages Per Sec
[2016-04-08 10:59:51][4538][DEBUG] got service job: SQLSERVER - MSSQL Page Splits Per Sec
[2016-04-08 10:59:51][4537][DEBUG] got service job: SQLSERVER - MSSQL Readaheads Per Sec
[2016-04-08 10:59:51][4538][DEBUG] got host job: windows9x5check_period
[2016-04-08 10:59:51][4537][DEBUG] got host job: printer9x5checks
[2016-04-08 10:59:51][4540][DEBUG] got service job: swordfish - DNS Resolution
[2016-04-08 10:59:55][4538][DEBUG] got service job: exchangeserver22 - Memory Usage
[2016-04-08 10:59:56][4537][DEBUG] got service job: localhost - PassiveServiceChecks 1mn
[2016-04-08 10:59:57][4540][DEBUG] got service job: shareinfinite- Multi Address Ping
[2016-04-08 10:59:58][4539][DEBUG] got service job: appstuff - SSH
[2016-04-08 10:59:59][4537][DEBUG] got service job: windows9x5check_period - Disk - C
[2016-04-08 11:00:00][4536][DEBUG] got host job: <someotherip>
[2016-04-08 11:00:00][4538][DEBUG] got host job: server332
[2016-04-08 11:00:00][4537][DEBUG] got service job: swordfish - Ping
[2016-04-08 11:00:01][4538][DEBUG] got service job: someserver999- Check Disk
[2016-04-08 11:00:01][4538][DEBUG] check exited with exit code > 3. Exit: 255
[2016-04-08 11:00:01][4538][DEBUG] stdout:
[2016-04-08 11:00:02][4537][DEBUG] got service job: windows9x5check_period - Eventlog
[2016-04-08 11:00:03][4538][DEBUG] got service job: exchangeserver22 - Ping
[2016-04-08 11:00:04][4964][DEBUG] child started with pid: 4964
[2016-04-08 11:00:04][4540][DEBUG] got service job: server777 - SQL Server
[2016-04-08 11:00:05][4540][DEBUG] got service job: server777 - Ping
[2016-04-08 11:00:06][4539][DEBUG] got service job: localhost - ActiveServiceChecks 1mn
[2016-04-08 11:00:07][4537][DEBUG] got service job: server777 - CPU Load
[2016-04-08 11:00:08][4537][DEBUG] got service job: windows9x5check_period - Memory Usage
[2016-04-08 11:00:09][4538][DEBUG] got host job: server2012
[2016-04-08 11:00:10][4537][DEBUG] got service job: swordfish - SSL Certificate
[2016-04-08 11:00:10][4980][DEBUG] child started with pid: 4980
[2016-04-08 11:00:10][4539][DEBUG] got host job: swordfish
[2016-04-08 11:00:10][4540][DEBUG] got host job: windows9x5check_period
[2016-04-08 11:00:10][4537][DEBUG] got host job: serverrrrr21
[2016-04-08 11:00:11][4540][DEBUG] got service job: windows9x5check_period - CPU Load
[2016-04-08 11:00:12][4537][DEBUG] got service job: nrpe9x5checkperiod - Total Processes
[2016-04-08 11:00:13][4537][DEBUG] got service job: server777 - Uptime
[2016-04-08 11:00:14][4539][DEBUG] got service job: swordfish - DNS IP Match
[2016-04-08 11:00:15][4537][DEBUG] got service job: server777 - MountPoint - M:Star_ReportLog
[2016-04-08 11:00:16][4537][DEBUG] got service job: exchangeserver22 - Exchange_RPC_User_Count
[2016-04-08 11:00:17][4540][DEBUG] got service job: someserver999- Current Load
[2016-04-08 11:00:17][4540][DEBUG] check exited with exit code > 3. Exit: 255
[2016-04-08 11:00:17][4540][DEBUG] stdout:
[2016-04-08 11:00:18][4537][DEBUG] got service job: hamster - Eventlog
[2016-04-08 11:00:19][4537][DEBUG] got service job: serverxyzz- Current Users
[2016-04-08 11:00:20][4540][DEBUG] got service job: sharechanger - CPU Load
[2016-04-08 11:00:20][4538][DEBUG] got host job: exchangeserver22
[2016-04-08 11:00:20][4980][DEBUG] got host job: nrpe9x5checkperiod
[2016-04-08 11:00:20][4536][DEBUG] got host job: localhost
[2016-04-08 11:00:21][4536][DEBUG] got service job: nrpe9x5checkperiod - File System Space
[2016-04-08 11:00:22][4537][DEBUG] check exited with exit code > 3. Exit: 255
[2016-04-08 11:00:22][4537][DEBUG] stdout:
[2016-04-08 11:00:22][4539][DEBUG] got service job: exchangeserver22 - Exchange Connection Count
[2016-04-08 11:00:23][4540][DEBUG] got service job: ARCHITECT - Ping
[2016-04-08 11:00:24][4539][DEBUG] got service job: exchangeserver22 - Active_Virtual_Memory_in_MB
[2016-04-08 11:00:26][4536][DEBUG] got service job: server777 - IIS World Wide Web Publishing Service
[2016-04-08 11:00:27][4538][DEBUG] got service job: server777 - Memory Usage
[2016-04-08 11:00:28][4539][DEBUG] got service job: someserver999- Current Users
[2016-04-08 11:00:28][4539][DEBUG] check exited with exit code > 3. Exit: 255
[2016-04-08 11:00:28][4539][DEBUG] stdout:
[2016-04-08 11:00:30][4538][DEBUG] got service job: exchangeserver22 - RPC_HTTP_Connection_Count
[2016-04-08 11:00:30][4980][DEBUG] got host job: serverrrrr21
[2016-04-08 11:00:30][4539][DEBUG] got host job: server777
[2016-04-08 11:00:30][4536][DEBUG] got host job: se1rverrrrr21
[2016-04-08 11:00:31][4537][DEBUG] got service job: localhost - ExternalCommandsUsed 1mn
[2016-04-08 11:00:32][4537][DEBUG] got service job: nrpe9x5checkperiod - Swap
[2016-04-08 11:00:34][4980][DEBUG] got service job: AliasLongFixingTester - Current Load
[2016-04-08 11:00:35][5095][DEBUG] child started with pid: 5095
[2016-04-08 11:00:35][4538][DEBUG] got service job: localhost - ActiveHostChecks 1mn
[2016-04-08 11:00:36][4540][DEBUG] got service job: nagiosxihost - Current Load
[2016-04-08 11:00:38][4537][DEBUG] got host job: sharechanger
[2016-04-08 11:00:40][4537][DEBUG] got service job: localhost - PassiveHostChecks 1mn
[2016-04-08 11:00:40][4536][DEBUG] got host job: nagiosxihost
[2016-04-08 11:00:40][4540][DEBUG] got host job: AliasLongFixingTester
[2016-04-08 11:00:41][4980][DEBUG] got service job: server777 - Eventlog
[2016-04-08 11:00:42][4538][DEBUG] got service job: server2012 - Uptime
[2016-04-08 11:00:43][4537][DEBUG] got service job: appstuff - Current Load
[2016-04-08 11:00:44][4536][DEBUG] got service job: nagiosxihost - Current Users
[2016-04-08 11:00:45][4539][DEBUG] got service job: hamster - Ping
[2016-04-08 11:00:46][4980][DEBUG] got service job: nrpe9x5checkperiod - Ping
[2016-04-08 11:00:49][4537][DEBUG] got service job: server2012 - Memory Usage
[2016-04-08 11:00:50][4536][DEBUG] got service job: dragon - CPU Load
[2016-04-08 11:00:50][4540][DEBUG] got service job: <SOMEIP>- Input / Output for VMHost
[2016-04-08 11:00:50][4540][DEBUG] Using Embedded Perl interpreter for: /usr/local/nagios/libexec/check_esx3.pl
[2016-04-08 11:00:50][4539][DEBUG] got service job: <SOMEIP>- Services for VMHost
[2016-04-08 11:00:50][4539][DEBUG] Using Embedded Perl interpreter for: /usr/local/nagios/libexec/check_esx3.pl
[2016-04-08 11:00:50][4980][DEBUG] got service job: server332 - MSSQL Average Wait Time
[2016-04-08 11:00:51][4540][DEBUG] got service job: server332 - MSSQL Log Shrinks
[2016-04-08 11:00:51][4539][DEBUG] got service job: server332 - MSSQL Target Pages Per Sec
[2016-04-08 11:00:51][4980][DEBUG] got service job: localhost - PassiveServiceChecks 1mn
[2016-04-08 11:00:52][4980][DEBUG] got service job: hamster - Check log3
[2016-04-08 11:00:53][4539][DEBUG] got service job: appstuff - Swap
[2016-04-08 11:00:54][4540][DEBUG] got service job: exchangeserver22 - HTTP_PROXY_Unique_Users
[2016-04-08 11:00:55][4539][DEBUG] got service job: hamster - Memory Physical RAM Usage
[2016-04-08 11:00:55][4538][DEBUG] got service job: someserver999- Ping
[2016-04-08 11:00:56][4540][DEBUG] got service job: sharechanger - Disk - C
[2016-04-08 11:00:57][4540][DEBUG] got service job: exchangeserver - HTTP_PROXY_Unique_Users
[2016-04-08 11:00:58][4539][DEBUG] got service job: nagiosxihost - Total Processes
[2016-04-08 11:00:59][4538][DEBUG] got service job: windows9x5check_period - Ping
[2016-04-08 11:01:00][4980][DEBUG] got service job: hamster - Disk - C
[2016-04-08 11:01:00][4537][DEBUG] got host job: dragon
[2016-04-08 11:01:00][4538][DEBUG] got host job: server2012
[2016-04-08 11:01:00][4536][DEBUG] got host job: nagiosxihost
[2016-04-08 11:01:00][4540][DEBUG] got host job: exchangeserver22
[2016-04-08 11:01:00][4980][DEBUG] got host job: hamster
[2016-04-08 11:01:01][4537][DEBUG] got service job: exchangeserver22 - Uptime
[2016-04-08 11:01:02][4540][DEBUG] got service job: appstuff - Ping
[2016-04-08 11:01:03][4536][DEBUG] got service job: localhost - ActiveServiceChecks 1mn
[2016-04-08 11:01:04][4537][DEBUG] got service job: appstuff - Total Processes
[2016-04-08 11:01:05][4540][DEBUG] got service job: someserver999- Total Processes
[2016-04-08 11:01:05][4540][DEBUG] check exited with exit code > 3. Exit: 255
[2016-04-08 11:01:05][4540][DEBUG] stdout:
[2016-04-08 11:01:06][4536][DEBUG] got service job: exchangeserver - Exchange_RPC_Average_Latency
[2016-04-08 11:01:06][5394][DEBUG] child started with pid: 5394
[2016-04-08 11:01:07][4539][DEBUG] got service job: swordfish - HTTP
[2016-04-08 11:01:08][4980][DEBUG] got service job: serverxyzz- Ping
[2016-04-08 11:01:09][4536][DEBUG] got service job: exchangeserver - Exchange_OWA_Unique_User_Count
[2016-04-08 11:01:10][4536][DEBUG] got service job: serverxyzz- Current Load
[2016-04-08 11:01:10][4537][DEBUG] got host job: serverrrrr21
[2016-04-08 11:01:11][4536][DEBUG] check exited with exit code > 3. Exit: 255
[2016-04-08 11:01:11][4536][DEBUG] stdout:
[2016-04-08 11:01:12][4536][DEBUG] got service job: exchangeserver - Ping
[2016-04-08 11:01:13][4537][DEBUG] got service job: exchangeserver22 - Exchange_User_Count
[2016-04-08 11:01:14][4540][DEBUG] got service job: exchangeserver - Uptime
[2016-04-08 11:01:15][4536][DEBUG] got service job: sharechanger - Memory Usage
[2016-04-08 11:01:17][4539][DEBUG] got service job: exchangeserver22 - Disk - C
[2016-04-08 11:01:17][4540][DEBUG] got service job: exchangeserver - Exchange Connection Count
[2016-04-08 11:01:18][4536][DEBUG] got host job: servepvs
[2016-04-08 11:01:19][4539][DEBUG] got service job: server777 - MountPoint - M:Star_Report1
[2016-04-08 11:01:20][4539][DEBUG] got service job: server2012 - Ping
[2016-04-08 11:01:20][4980][DEBUG] got host job: se1rverrrrr21
[2016-04-08 11:01:20][4536][DEBUG] got host job: exchangeserver22
[2016-04-08 11:01:20][4537][DEBUG] got service job: hamster - Memory Paging File Usage
[2016-04-08 11:01:21][4537][DEBUG] got service job: hamster - Memory Usage
[2016-04-08 11:01:22][4540][DEBUG] got service job: exchangeserver22 - Exchange_RPC_Average_Latency
[2016-04-08 11:01:24][4536][DEBUG] got service job: exchangeserver22 - Processor_Timing
[2016-04-08 11:01:25][4540][DEBUG] got service job: citrixtest9x5period - Citrix Print Manager Service
[2016-04-08 11:01:26][4537][DEBUG] got service job: exchangeserver - Disk - C
[2016-04-08 11:01:27][4536][DEBUG] got service job: exchangeserver - Eventlog
[2016-04-08 11:01:28][4537][DEBUG] got service job: exchangeserver - Exchange_User_Count
[2016-04-08 11:01:30][4537][DEBUG] got service job: server2012 - CPU Usage
[2016-04-08 11:01:30][4538][DEBUG] got host job: server2012
[2016-04-08 11:01:31][4536][DEBUG] got service job: localhost - ExternalCommandsUsed 1mn
[2016-04-08 11:01:32][4540][DEBUG] got service job: serverxyzz- Total System Space
[2016-04-08 11:01:33][4536][DEBUG] got service job: exchangeserver - CPU Load
[2016-04-08 11:01:34][4536][DEBUG] got service job: AliasLongFixingTester - Current Load
[2016-04-08 11:01:35][4540][DEBUG] check exited with exit code > 3. Exit: 255
[2016-04-08 11:01:35][4540][DEBUG] stdout:
[2016-04-08 11:01:35][4536][DEBUG] got service job: citrixtest9x5period - CPU Load
[2016-04-08 11:01:37][4540][DEBUG] got service job: localhost - ActiveHostChecks 1mn
[2016-04-08 11:01:37][5510][DEBUG] child started with pid: 5510
[2016-04-08 11:01:38][4536][DEBUG] got service job: exchangeserver22 - Eventlog
[2016-04-08 11:01:39][4539][DEBUG] got service job: exchangeserver - Memory Usage
[2016-04-08 11:01:40][4536][DEBUG] got service job: exchangeserver22 - Exchange_OWA_Unique_User_Count
[2016-04-08 11:01:40][4537][DEBUG] got host job: exchangeserver22
[2016-04-08 11:01:40][4540][DEBUG] got host job: se1rverrrrr21
[2016-04-08 11:01:41][4537][DEBUG] got service job: hamster - CPU Load NRPE Counters
[2016-04-08 11:01:43][4538][DEBUG] got service job: localhost - PassiveHostChecks 1mn
[2016-04-08 11:01:44][4540][DEBUG] got service job: server777 - MountPoint - M:Star_Report1 FREE
[2016-04-08 11:01:46][4536][DEBUG] got service job: localhost - PassiveServiceChecks 1mn
[2016-04-08 11:01:47][4536][DEBUG] got service job: server332 - MSSQL Log Truncations
[2016-04-08 11:01:48][4540][DEBUG] got service job: serverxyzz- Swap
[2016-04-08 11:01:50][4537][DEBUG] got service job: citrixtest9x5period - Uptime
[2016-04-08 11:01:50][4537][DEBUG] got service job: SQLSERVER - MSSQL Lock Timeouts Per Sec
[2016-04-08 11:01:50][4538][DEBUG] got service job: SQLSERVER - MSSQL Lock Wait Times
[2016-04-08 11:01:50][4536][DEBUG] got service job: SQLSERVER - MSSQL Lock Waits Per Sec
[2016-04-08 11:01:50][4980][DEBUG] got service job: SQLSERVER - MSSQL Page Looks Per Sec
[2016-04-08 11:01:50][4539][DEBUG] got service job: SQLSERVER - MSSQL Page Reads Per Sec
[2016-04-08 11:01:50][4537][DEBUG] got service job: localhost - AvgHostExecTime
[2016-04-08 11:01:50][4536][DEBUG] got service job: localhost - AvgServiceExecTime
[2016-04-08 11:01:50][4538][DEBUG] got service job: localhost - ExternalCommandsUsed 5mn
[2016-04-08 11:01:50][4980][DEBUG] got service job: localhost - HighCommandBufferUsage
[2016-04-08 11:01:51][4539][DEBUG] got service job: localhost - PassiveHostChecks 15mn
[2016-04-08 11:01:51][4537][DEBUG] got service job: serverxyzz- Total Zombie Processes
[2016-04-08 11:01:51][4540][DEBUG] check exited with exit code > 3. Exit: 255
[2016-04-08 11:01:51][4540][DEBUG] stdout:
[2016-04-08 11:01:51][4537][DEBUG] check exited with exit code > 3. Exit: 255
[2016-04-08 11:01:51][4537][DEBUG] stdout:
[2016-04-08 11:01:52][4536][DEBUG] got service job: server2012 - IIS Web Server
[2016-04-08 11:01:53][4539][DEBUG] got service job: citrixtest9x5period - Eventlog
[2016-04-08 11:01:54][4537][DEBUG] got service job: server2012 - Drive C: Disk Usage
[2016-04-08 11:01:55][4540][DEBUG] got service job: citrixtest9x5period - Citrix XML Service
[2016-04-08 11:01:56][4538][DEBUG] got host job: appstuff
[2016-04-08 11:01:58][4540][DEBUG] got service job: shareinfinite- Memory Usage
[2016-04-08 11:01:59][4538][DEBUG] got service job: localhost - ActiveServiceChecks 1mn
[2016-04-08 11:02:00][4538][DEBUG] got service job: citrixtest9x5period - Citrix Services Manager Service
[2016-04-08 11:02:00][4980][DEBUG] got host job: SP13BPR01DAR
[2016-04-08 11:02:00][4540][DEBUG] got host job: tibbeqa01dar
[2016-04-08 11:02:01][4539][DEBUG] got service job: sharechanger - Eventlog
[2016-04-08 11:02:02][4540][DEBUG] got service job: sharechanger - Uptime
[2016-04-08 11:02:03][4540][DEBUG] got service job: appstuff - Current Users
[2016-04-08 11:02:04][4538][DEBUG] got service job: sharechanger - Ping
[2016-04-08 11:02:05][4536][DEBUG] got service job: dragon - Disk - C
[2016-04-08 11:02:06][4537][DEBUG] got service job: shareinfinite- Disk - C
[2016-04-08 11:02:07][4540][DEBUG] got service job: citrixtest9x5period - Citrix Independent Management Architecture Service
[2016-04-08 11:02:08][4539][DEBUG] got service job: shareinfinite- Uptime
[2016-04-08 11:02:08][5775][DEBUG] child started with pid: 5775
[2016-04-08 11:02:09][4537][DEBUG] got service job: shareinfinite- Eventlog
[2016-04-08 11:02:10][4540][DEBUG] got service job: shareinfinite- CPU Load
[2016-04-08 11:02:11][4537][DEBUG] got service job: exchangeserver - Exchange_RPC_User_Count
[2016-04-08 11:02:12][4540][DEBUG] got service job: nagiosxihost - File System Space
[2016-04-08 11:02:13][4537][DEBUG] got service job: citrixtest9x5period - Citrix Group Policy Engine
[2016-04-08 11:02:14][4537][DEBUG] got service job: citrixtest9x5period - Citrix XTE Server
[2016-04-08 11:02:15][4539][DEBUG] got service job: dragon - Eventlog
[2016-04-08 11:02:16][4537][DEBUG] got service job: appstuff - File System Space
[2016-04-08 11:02:18][4537][DEBUG] got service job: dragon - Memory Usage
[2016-04-08 11:02:19][4536][DEBUG] got service job: appstuff - check_log3_kpi_SQL
[2016-04-08 11:02:20][4540][DEBUG] got service job: exchangeserver22 - Exchange_Pending_Ping_Count
[2016-04-08 11:02:20][4540][DEBUG] got host job: exchangeserver22
[2016-04-08 11:02:20][4538][DEBUG] got service job: citrixtest9x5period - Citrix MFCOM Service
bheden
Can we turn the debug level up to 3 on the worker and get more output from the worker log, please?
Also, just to make sure everything went smoothly, can I see the output of:
and
I'm assuming that the server and worker are on the same server, but if they aren't: I'd like to see the output from iptables for both server and worker.
Thanks!
yum list installed | grep gearmanCode: Select all
iptables -LThanks!
Nagios Enterprises
Senior Developer
Nagios Enterprises
Senior Developer
