I'm using check_hp-2.20 plugin to monitor HP Proliant hardware. I'm able to cover most of the requirement but unable to find details for following components.
Can anyone help me to find suitable plugin for these components?
Batteries
Connectors
Disk Enclosures
Enclosures
Voltage Sensors
Regards
Sebastian
HP Proliant Hardware Monitor
Re: HP Proliant Hardware Monitor
Have you taken a look at our exchange to see if anything would work for you?
https://exchange.nagios.org/index.php?o ... d=check_hp
If none of those will work, are you able to find that information over a SNMP through a specific MIB/OID at all?
