500MB/Daily Average Query
nathanplatt
Post by nathanplatt »
Hi Everyone,
Is there a way from the log server I can monitor the data throughput to avoid passing the 500MB/Day average. I can't see anything obvious on the system itself? How does it know and report this information, or is it hard coded into the software.
I'm concerned as adding in all our servers will probably push this in the first instance and then it should level out
Nathan
hsmith
Agent Smith
Re: 500MB/Daily Average Query
Post by hsmith »
If you go to Administration > System > Index Status you can see how much data per day you're getting in.
Former Nagios Employee.
me.
nathanplatt
Ah brilliant, 600MB total, so no chance of breaching the 500MB day average at the moment.
Thanks for this, please feel free to close the case.
