Db2 issue
raamardhani7
Db2 issue
Post by raamardhani7 »
Hi Team,
We are working on the custom scripts to get the required information from the remote server using NRPE.
Here is the script that is written for the same.
#!/bin/sh
#         Title: DB2 Database Transaction Log Utilization
#        Author: Chris Park
#          Date: Mar. 11th, 2016
# Example usage: ./check_Db2_transaction_log_util.sh [Database Name] [Database Profile Location]
# This script checks the database Transaction Log Utilization.
# Retrieves a critical alarm when the total log used percentage is bigger than the given size in critical,
# or retrieves a warning alarm when the total log used percentage is bigger than the provided,
# comparing with the allocated utilization.
SERVER=`hostname`
DBNAME="$1"
PROFILE="$2"
. $PROFILE
# Nagios return codes
STATE_OK=0
STATE_WARNING=1
STATE_CRITICAL=2
STATE_UNKNOWN=3
PROGNAME=$(basename $0)
print_usage() {
        echo ""
        echo "$PROGNAME"
        echo ""
        echo "Usage: $PROGNAME $ARG1$ $ARG2$"
        echo ""
        echo "# $ARG1$: Database Name"
        echo "# $ARG2$: Database Profile Location"
        echo ""
        echo ""
TMP_OUTPUT="/tmp/db2_trans_log_util_out"
db2 connect to $DBNAME| db2 'select substr(DB_NAME,1,10) DB_NAME,LOG_UTILIZATION_PERCENT total_log_used_kb, total_log_available_kb from SYSIBMADM.LOG_UTILIZATION'|grep $DBNAME > $TMP_OUTPUT
TMP_DB_USED_KB=`cat "$TMP_OUTPUT" | awk '{print $2}'`
TMP_DB_AVAILABLE_KB=`cat "$TMP_OUTPUT" | awk '{print $3}'`
if [[ "$TMP_DB_USED_KB" == "0.00" ]]
   then
      DB_USED_PERCENT=0
#elif [[ "$TMP_DB_USED_KB" == "" ]]
elif [[ -z "$TMP_DB_USED_KB" ]]
   then
      DB_USED_PERCENT=0
   else
      DB_USED_PERCENT=`echo "$TMP_DB_USED_KB * 100" |bc|sed 's/[.].*//'`
fi
#if [[ -z "$TMP_DB_AVAILABLE_KB" -eq "" ]]
if [[ -z "$TMP_DB_AVAILABLE_KB" ]]
   then
      DB_AVAILABLE_MB=0
   else
      DB_AVAILABLE_MB=`expr "$TMP_DB_AVAILABLE_KB" / 1024`
fi
if [ -f $TMP_OUTPUT ]
   then
       rm -f $TMP_OUTPUT
fi
#3979811
SYMBOL="%"
#CRITICAL State
CDB_USED_PERCENT=90
# WARNING State
WDB_USED_PERCENT=85
if [[ $DB_USED_PERCENT -gt $CDB_USED_PERCENT ]]; then
     TEMP_STATUS="CRITICAL"
     RETURN_STATUS=$STATE_CRITICAL
elif [[ $DB_USED_PERCENT -gt $WDB_USED_PERCENT ]]; then
     TEMP_STATUS="WARNING"
     RETURN_STATUS=$STATE_WARNING
else
     TEMP_STATUS="OK"
     RETURN_STATUS=$STATE_OK
fi
FINAL_STATUS="$TEMP_STATUS|Total_log_Used:$DB_USED_PERCENT${SYMBOL}, Toal_log_Available:${DB_AVAILABLE_MB}MB, Db_Name:$DBNAME"
echo $FINAL_STATUS
exit $RETURN_STATUS
We ran the script in remote server and the output is:
$ ./check_Db2_transaction_log_util.sh MCCD13X /db2/home/mccdev/sqllib/db2profile
OK|Total_log_Used:1%, Toal_log_Available:3886MB, Db_Name:MCCD13X
When we are running the same from Nagios server, we are not getting the desired results on the first instance. If the same command is run for 4 or 5 times, it is showing us the right information.
[root@lussvpnagiosxi00 ~]# /usr/local/nagios/libexec/check_nrpe -H dalcpldd10 -t 30 -c check_Db2_transaction_log_util.sh -a 'MCCD13X /db2/home/mccdev/sqllib/db2profile' -n
OK - Total log Used is 0 % and Toal log available is 0(MB) of MCCD13X on the server dalcpldd10
You have new mail in /var/spool/mail/root
OK - Total log Used is 1 % and Toal log available is 3886(MB) of MCCD13X on the server dalcpldd10
Check command configured in nrpe:
command[check_Db2_transaction_log_util.sh]=/usr/local/nagios/libexec/check_Db2_transaction_log_util.sh $ARG1$
Could you please help us here. thanks.
raamardhani7
Re: Db2 issue
Therefore, when we ran the db2 command on the command prompt, it works. However, when you run through the shell script, it does not work properly. It's very random.
raamardhani7
Re: Db2 issue
I also specified absolute path in the script as below. However, it's still very random output...
#!/usr/bin/bash
export PATH=$PATH:/usr/bin:/etc:/usr/sbin:/usr/ucb:/usr/bin/X11:/sbin:/usr/java5/jre/bin:/usr/java5/bin:/db2/home/mccdev/sqllib/bin:/db2/home/mccdev/sqllib/adm:/db2/home/mccdev/sqllib/misc
raamardhani7
Re: Db2 issue
Please close ticket. I resolved this matter.
