No performance data from check_snmp
ljblom
Post by ljblom »
We are using a ControlByWeb X300 web relay at one of our sites. We have written a service to retrieve the temperature vi SNMP:
$USER1$/check_snmp -H $HOSTADDRESS$ -o .1.3.6.1.4.1.30586.10.11.0 $ARG1$
The command is working, however it's only returning a string:
COMMAND: /usr/local/nagios/libexec/check_snmp -H 10.x.x.x -o .1.3.6.1.4.1.30586.10.11.0 -C public
OUTPUT: SNMP OK - "0" |
The output is a string, so we are not logging any performance data for this currently. How can we modify this command/service to log performance data?
Thank you for your help.
Re: No performance data from check_snmp
Does this OID return a string value or a integer/counter/gauge?
can you run
snmpget 10.x.x.x v 2c -c public .1.3.6.1.4.1.30586.10.11.0
and post the response
ljblom
Post by ljblom »
Thank you for the reply. Actually, found a very simple solution. I hadn't set warning or critical levels. Just adding the warning/critical thresholds changed the output from a string to integer, enabling performance data to be logged. I don't know why, but I'll take it:)
Thank you for your quick response none the less.
bwallace
Post by bwallace »
Thanks for the update and glad to hear you found a solution. Closing thread now....
