Graphs not updated after migration to new server
altsysrq
Post by altsysrq »
I recently migrated to a new server. I restored the data from the old server to the new. Now graphs do not show up for anything recent.
tail -10 /usr/local/nagios/var/perfdata.log
2016-04-13 11:00:32 [15370] [0] *** TIMEOUT: /usr/local/nagios/var/spool/perfdata//1460563203.perfdata.service-PID-15370 deleted
2016-04-13 11:00:32 [15373] [0] *** TIMEOUT: Deleting current file to avoid NPCD loops
2016-04-13 11:00:32 [15372] [0] *** TIMEOUT: Deleting current file to avoid NPCD loops
2016-04-13 11:00:32 [15373] [0] *** TIMEOUT: Please check your process_perfdata.cfg
2016-04-13 11:00:32 [15370] [0] *** process_perfdata.pl terminated on signal ALRM
2016-04-13 11:00:32 [15372] [0] *** TIMEOUT: Please check your process_perfdata.cfg
2016-04-13 11:00:32 [15373] [0] *** TIMEOUT: /usr/local/nagios/var/spool/perfdata//1460563219.perfdata.service-PID-15373 deleted
2016-04-13 11:00:32 [15372] [0] *** TIMEOUT: /usr/local/nagios/var/spool/perfdata//1460563219.perfdata.host-PID-15372 deleted
2016-04-13 11:00:32 [15373] [0] *** process_perfdata.pl terminated on signal ALRM
2016-04-13 11:00:32 [15372] [0] *** process_perfdata.pl terminated on signal ALRM
I can't get the above to update after 2016-04-13 11:00:32. I am not sure if it is supposed to since I attempted to fixed the timeouts based on these directions: https://support.nagios.com/wiki/index.p ... ta_Timeout
tail -25 /usr/local/nagios/var/npcd.log
[04-13-2016 22:47:08] NPCD: Regular File: 1460602017.perfdata.service
[04-13-2016 22:47:08] NPCD: A thread was started on thread_counter = 0
[04-13-2016 22:47:08] NPCD: Have to wait: Filecounter = 1 - thread_counter = 1
[04-13-2016 22:47:08] NPCD: Processing file 1460602017.perfdata.service with ID 140352887666432 - going to exec /usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1460602017.perfdata.service
[04-13-2016 22:47:08] NPCD: Processing file '1460602017.perfdata.service'
[04-13-2016 22:47:08] NPCD: No more files to process... waiting for 15 seconds
[04-13-2016 22:47:23] NPCD: Found 4 files in /usr/local/nagios/var/spool/perfdata/
[04-13-2016 22:47:23] NPCD: DEBUG: load 0.440000/10.000000
[04-13-2016 22:47:23] NPCD: ThreadCounter 0/5 File is .
[04-13-2016 22:47:23] NPCD: ThreadCounter 0/5 File is ..
[04-13-2016 22:47:23] NPCD: ThreadCounter 0/5 File is 1460602032.perfdata.service
[04-13-2016 22:47:23] NPCD: Regular File: 1460602032.perfdata.service
[04-13-2016 22:47:23] NPCD: A thread was started on thread_counter = 0
[04-13-2016 22:47:23] NPCD: ThreadCounter 1/5 File is 1460602033.perfdata.host
[04-13-2016 22:47:23] NPCD: Regular File: 1460602033.perfdata.host
[04-13-2016 22:47:23] NPCD: Processing file 1460602032.perfdata.service with ID 140352887666432 - going to exec /usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1460602032.perfdata.service
[04-13-2016 22:47:23] NPCD: A thread was started on thread_counter = 1
[04-13-2016 22:47:23] NPCD: Processing file 1460602033.perfdata.host with ID 140352877086464 - going to exec /usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1460602033.perfdata.host
[04-13-2016 22:47:23] NPCD: Have to wait: Filecounter = 2 - thread_counter = 2
[04-13-2016 22:47:23] NPCD: Processing file '1460602032.perfdata.service'
[04-13-2016 22:47:23] NPCD: Processing file '1460602033.perfdata.host'
[04-13-2016 22:47:23] NPCD: No more files to process... waiting for 15 seconds
CentOS 7.2
Installation instructions:
https://assets.nagios.com/downloads/nag ... ctions.pdf
Backup/Restore instructions:
I am not sure where I went wrong. Any ideas?
Re: Graphs not updated after migration to new server
Post by Box293 »
Has increasing the timeout value again in /usr/local/nagios/etc/pnp/process_perfdata.cfg still not made any difference?
Did you try restarting npcd after this?
service npcd restart
Can you please run these commands on your Nagios XI host and send the output:
ls -al /usr/local/nagios/var/spool/perfdata/ | wc -l
ls -al /usr/local/nagios/var/spool/xidpe/ | wc -l
Can you please post these config files:
/usr/local/nagios/etc/pnp/npcd.cfg
/usr/local/nagios/etc/nagios.cfg
/etc/sysconfig/nagios
/etc/init.d/nagios
