language change not working
asardouk
Post by asardouk »
I'm trying to change the UI language for some users but it's not working. I set it to french from the admin account and even from the account information with a user account.No result , still in english.
Nagios XI 5.2.5 - CentOS Linux release 7.2.1511
bwallace
Re: language change not working
Post by bwallace »
This works fine for me here using XI versions 5.2.5 and 5.2.7.
To be clear, once you switch the language, are you logging out & then logging back in as the user who should see the UI in French?
Going forward, could you quickly reproduce the issue and then post these logs:
/usr/local/nagiosxi/var/cmdsubsys.log
/var/log/httpd/error_log
usr/local/nagios/var/nagios.log
asardouk
Post by asardouk »
I get it to work by replacing files with original ones :D
My colleague modified po file and when he compile to mo, just new modification are in. We found out than you need to untoggle fuzzy in "Poedit" to get all words in the mo file.
once done all modifications done, I'm going to send files to " [email protected] ". I'm working on french translation ;)
Thanks for help, you can close the topic.
bwallace
Post by bwallace »
Appreciate the update and thanks for sharing the solution, that maybe helpful later on. Good luck on the French translation! Closing thread now....
