Hi guys,
I don't know when this has changed but is used to work perfectly before.....
When I run Bulk Modifications, to change a single config option, I select 'check period' and purposefully don't put a new value because I do not want 'check period' at the service level to have a value because the template for the service check handles the check period. When I save and apply configuration the 'check period' doesn't get updated. This same is true for 'notification period'. I have thousands of checks with various groups of time periods that I need to maintain at the template level.
How can run bulk mods with value of blank for these periods? NOTE: when I change value to blank for interval settings it works just fine. Something about these periods... Sorry if this known issue.
Thx
Bulk Mods - Check Period not updating
Re: Bulk Mods - Check Period not updating
I just tried to do the same, and was able to replicate this. The Notification period, and check period both were not going blank.
I have filed a bug report for this, ID 8285. Thanks for letting us know.
Thank you for verifying and submitting the bugger.
Are we OK to close this thread brdr, or were there additional questions on the topic?
bheden
- Product Development Manager
Thanks for bringing this to our attention. We've fixed it on our end, and it will be available at the next release. In the meantime: if you need this functionality right now, you can run the following command on the NagiosXI server:
Hope this helps.
sed -i 's/.*SELECT id from.*/if \(\$timeperiod != \"\"\) { &/;s/\$value = \$timeperiod_id;/& }/' /usr/local/nagiosxi/html/includes/components/bulkmodifications/bulkmodifications.inc.phpAs of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
Nagios Enterprises
Senior Developer
Nagios Enterprises
Senior Developer
That is awesome. Ran it, then bulk'ed up. All good. Thx n plz close.
u guys rock!
u guys rock!
Glad we were able to help. We'll lock this thread now and feel free to open another should you require assistance with anything else.
