I installed Nagios Log and have been using it through the trial to determine whether we would like to purchase it. We are very happy with the product, however, upon the end of the trial the dashboard has gone blank (see screenshot) Is this supposed to happen or is it an issue?
Our products come with a 60-day free trial, after which you are capped at 500MB of logs per day, averaged over a week. If you exceed that limit you will see this screen when you go to load a dashboard. You'll either need to purchase a license or cut down on the amount of logs being sent.
