check_snmp - noSuchName
wesmat
Post by wesmat »
I am attempting to monitor an APC Symmetra UPS with snmp. Things are great using snmpwalk as well as a PHP script I am writing. But the check_snmp command gives me the following:
$ /usr/local/nagios/libexec/check_snmp -H 10.139.9.211 -C 'public' -P 1 -o .1.3.6.1.4.1.318.1.1.10.2.3.2.1.4
External command error: Error in packet
Reason: (noSuchName) There is no such variable name in this MIB.
Failed object: iso.3.6.1.4.1.318.1.1.10.2.3.2.1.4
when I try snmpwalk I get the following:
$ snmpwalk -v1 -c public 10.139.9.211 .1.3.6.1.4.1.318.1.1.10.2.3.2.1.4
SNMPv2-SMI::enterprises.318.1.1.10.2.3.2.1.4.1 = INTEGER: 72
I thought it might be the snmp version, so I switched to 2c and I get:
$ /usr/local/nagios/libexec/check_snmp -H 10.139.9.211 -C 'public' -P 2c -o .1.3.6.1.4.1.318.1.1.10.2.3.2.1.4
External command error: Timeout: No Response from 10.139.9.211:161
I am running all of this from an ssh session on the nagios xi server.
What am I doing wrong? I can send additional info if needed.
Re: check_snmp - noSuchName
Post by Box293 »
See here in the SNMP Walk output:
wesmat wrote:when I try snmpwalk I get the following:
The OID ends in .1
Try changing your command:
/usr/local/nagios/libexec/check_snmp -H 10.139.9.211 -C 'public' -P 1 -o .1.3.6.1.4.1.318.1.1.10.2.3.2.1.4.1
wesmat
Post by wesmat »
Thanks! Yes, adding .1 to the OID makes it work.
I am very new to SNMP - sorry for the simple question.
No problem - glad to see you got it working.
Marking this one as resolved, but feel free to create a new thread if you need any assistance in the future.
