Apologies for if this has already been posted before, couldn't find the specifics through a search...
I'm having troubles attempting to monitor traffic through a switch.
Using the check_local_mrtgtraf... it returns the status information (No output on stdout) stderr:
Any ideas or had this type of problem before?
Re: check_local_mrtgtraf
Further...
I have managed to configure this for one of my hosts, however it points to one log file created. therefore pointing the service at another host would be next to irrelevant as the log file will be the same one as the original.
For starters, could you post the corresponding command definition and service definition?
feel free to delete this. Been off the job for a while, found another way.
Thanks for that update, closing this one out now...
