I designed a dashboard "APPP5233" with graphs from Graph Explorer ==> Multistacked Performance Graph. The metrics are provided by one of the SQL Server plugins.
I wanted to use it as a template to generate similar dashboards for other servers. Anyways, when I tried to clone it to a new server "PBX010" a new cloned dashboard was created but I have no way to edit the graphs and they show old values from source server.
Is this possible even through editing of some configuration file on Nagios server?
How to change Cloned Dashboard?
Re: How to change Cloned Dashboard?
At this time, it isn't going to work that way to where you can change variables that are in dashlets.
If you'd like, I can file a feature request for this?
