Perfdata with incorrect timet attribute
[email protected]
Good morning,
our nagios XI platform is drawing perfdata with incorrect time. Machine time is configured OK (clock, timezone,..), but perfdata files have NAGIOS_TIMED attribute is incorrect.
By using time conversion tool we found that it is about 3 days ago.
What can be done to fix this? I am uploading screenshots of everything.
Thank you.
Thank you.
Re: Perfdata with incorrect timet attribute
Are you having the same issue will all hosts/services?
Can you run the following commands, and show the output?
Note: Modify the last command if you have mysql offloaded to a remote server.
Have you tried rebooting the server?
strings /etc/localtime | tail -1
grep timezone /etc/php.ini
echo 'select now();' | mysql -t -pnagiosxi
[email protected]
yes its the same for all graphs.
I have tried to reboot server several times with no luck. Also cannot find any related information by searching it on google, seems to be a strange behaviour. I am considering to reinstall full nagios server but I will prefer not to do it...
Here I am uploading the output of these commands. Seems that sql one has failed.
Thank you.
Thank you.
- Box293
- Too Basu
You did not type this command correctly:
echo 'select now();' | mysql -t -pnagiosxiAs of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
[email protected]
here it is the correct output.
[email protected]
And the current state of graphs.
Could you post the following files so we can review them?
/usr/local/nagios/etc/nagios.cfg
/usr/local/nagios/etc/pnp/process_perfdata.cfg
/usr/local/nagios/etc/pnp/config.php
[email protected]
seems that I found the problem: the server was too overloaded (200+ charge). It had over 500 services configured to be checked every second. I had to configure it to 3 seconds and graphs are being displayed. Could this be the reason?
Yes, that could be it. If the load is high for a period of time, the NPCD daemon and the process_perfdata script will stop graphing the performance data.
The settings can be changed to a higher value so the will continue to process the performance data. Here is how to do that.
Edit the following file on the XI server
And increase the following setting. You can double or quadruple it.
Next, edit this file
Save the files out and run the following to restart the processes so they will reload the changed settings.
Post if you have any more questions.
/usr/local/nagios/etc/pnp/process_perfdata.cfgCode: Select all
TIMEOUT = 5Code: Select all
/usr/local/nagios/etc/pnp/npcd.cfgCode: Select all
load_threshold = 10.0Code: Select all
service npcd restart
service nagios restartBe sure to check out our Knowledgebase for helpful articles and solutions!
