I getting an error when I instaaling Nsclent++ agent in windows servers.
Please help me with this.
Gomathsyhankar selvakumar
Unable install NSclient ++ agent in windows server
gselvakumar
Thanks & Regards,
Gomathyshankar Selvakumar
Re: Unable install NSclient ++ agent in windows server
What version of windows are you running, and what version of NSClient++ are you trying to install?
Is your OS up to date?
gselvakumar
We are using Windows OS-Microsoft(R) Windows(R) Server 2003, Standard Edition and Nsclient++ Version-0.4.3.143 (Stable release)
Only few servers are having issue ,rest of the server with same OS and Nsclient version are working fine.
Thanks & Regards,
I would see if you can install something like version 3.9 of NSClient. I've seen issues during some of my remote sessions where the newer versions of NSClient were not compatible with that old of a version Windows.
Former Nagios Employee.
me.
me.
gselvakumar
Issue sorted .I tried using lower version of package and it is working.
Thanks You.
Thanks You.
Thanks & Regards,
Thanks for that update and glad to hear the issue is resolved. I'll close this thread now, but feel free to open another if you questions about anything else.
