The required libraries for the Active Directory integration
wat_006
Post by wat_006 »
I've attempted to update php on the nagios vm
I'm able to login as the local user, but when I attempt to login via AD I receive the following message "The required libraries for the Active Directory integration component are missing." Any suggestions?
If I roll back the vm image, all is well, but I would really like to get this working as the php upgrade I did removed a ton of php related vulnerabilities.
We're using the trail version at the moment.
Re: The required libraries for the Active Directory integrat
What version of PHP did you upgrade to, and what OS are you running? php -v
wat_006
Post by wat_006 »
php -v shows version 5.6.20
There is also this line in the output "PHP Warning: PHP Startup: Unable to load dynamic library '/usr/lib64/php/modules/ixed.5.3.lin' - /usr/lib64/php/modules/ixed.5.3.lin: cannot open shared object file: No such file or directory in Unknown on line 0"
OS is CentOS 6.7 which is what the downloadable VM comes with.
ssax
Dreams In Code
Post by ssax »
What is the output of this:
rpm -qa | grep php
Thank you
If you have the source for Nagios XI still on the server, you can reinstall sourceguardian by following this procedure.
Change to the /tmp/nagiosxi folder and run the following script yo update Sourceguardian PHP module.
./install-sourceguardian-extension.sh
If you don't have the source for XI on the system, follow these instructions to download and extract the data.
cd /tmp
wget http://assets.nagios.com/downloads/nagiosxi/xi-latest.tar.gz
tar xvfz xi-latest.tar.gz
cd nagiosxi
Try that and let us know if this works for you.
wat_006
Post by wat_006 »
Output is
php56w-cli-5.6.20-1.w6.x86_64
php56w-mysql-5.6.20-1.w6.x86_64
php56w-xml-5.6.20-1.w6.x86_64
php56w-common-5.6.20-1.w6.x86_64
php56w-pdo-5.6.20-1.w6.x86_64
php56w-gd-5.6.20-1.w6.x86_64
php56w-devel-5.6.20-1.w6.x86_64
php56w-5.6.20-1.w6.x86_64
php56w-mbstring-5.6.20-1.w6.x86_64
php56w-opcache-5.6.20-1.w6.x86_64
php56w-intl-5.6.20-1.w6.x86_64
php56w-mcrypt-5.6.20-1.w6.x86_64
I extracted the data from xi-latest.tar.gz
when trying to run ./install-sourceguardian-extension.sh I receive the following warning
Archive: sourceguardian/ixed4.lin.x86-32.zip
checkdir: cannot create extraction directory: /usr/lib/php/modules
The old Sourceguardian file has to be moved first.
Login to XI as root, run the following and then continue on with the previous instructions.
mv /etc/php.d/sourceguardian.ini /tmp
wat_006
Post by wat_006 »
Is rerunning sourceguardian.ini going to revert php back to it's original version?
To add to this conundrum, the Core Config Manager is not available.
No, running the script
Will install the correct Sourceguardian PHP module for the version of PHP you upgraded to and create a new sourceguardian.ini reflecting that.
It will not revert PHP back to the old version.
