/etc/httpd/modules/mod_auth_basic.so: invalid ELF header
Muthulinux
Post by Muthulinux »
Hi All,
I used nagios XI to monitor my production servers. today we did online vm migration after that my nagios xi machine is not starting up properly.
When i checked service httpd status it shows like below
httpd is stopped
then we tried to start it by using this command "service httpd start" but getting below error
Starting httpd: httpd: Syntax error on line 150 of /etc/httpd/conf/httpd.conf: Cannot load /etc/httpd/modules/mod_auth_basic.so into server: /etc/httpd/modules/mod_auth_basic.so: invalid ELF header
[FAILED]
then we checked using this command " ldd /etc/httpd/modules/mod_auth_basic.so " but getting below error.
not a dynamic executable
then i tried to check using "readelf -d mod_auth_basic.so" this command but getting below error.
readelf: Error: 'mod_auth_basic.so': No such file
Could any one please help me out on this? It is very major server which is used to monitor the all my production servers.
Re: /etc/httpd/modules/mod_auth_basic.so: invalid ELF header
Please post your /etc/httpd/conf/httpf.conf file for us to look at.
Additionally, what version of XI are you running? What version of apache? apachectl -v
Muthulinux
Dear Kenedy,
Now i am unable to start the VM itself. i will update you once i fix the VM storage issue.
Thank you so much for your intervention
We will keep this topic open for you
