WebHost failed to process a request.
Sender Information: System.ServiceModel.ServiceHostingEnvironment+HostingManager/12036987
Exception: System.ServiceModel.ServiceActivationException: The service '/AnnuityBusinessRulesService.svc' cannot be activated due to an exception during compilation. The exception message is: Memory gates checking failed because the free memory (69607424 bytes) is less than 5% of total memory. As a result, the service will not be available for incoming requests. To resolve this, either reduce the load on the machine or adjust the value of minFreeMemoryPercentageToActivateService on the serviceHostingEnvironment config element.. ---> System.InsufficientMemoryException: Memory gates checking failed because the free memory (69607424 bytes) is less than 5% of total memory. As a result, the service will not be available for incoming requests. To resolve this, either reduce the load on the machine or adjust the value of minFreeMemoryPercentageToActivateService on the serviceHostingEnvironment config element.
at System.ServiceModel.Activation.ServiceMemoryGates.Check(Int32 minFreeMemoryPercentage, Boolean throwOnLowMemory, UInt64& availableMemoryBytes)
at System.ServiceModel.ServiceHostingEnvironment.HostingManager.CheckMemoryCloseIdleServices(EventTraceActivity eventTraceActivity)
at System.ServiceModel.ServiceHostingEnvironment.HostingManager.EnsureServiceAvailable(String normalizedVirtualPath, EventTraceActivity eventTraceActivity)
--- End of inner exception stack trace ---
at System.ServiceModel.ServiceHostingEnvironment.EnsureServiceAvailableFast(String relativeVirtualPath, EventTraceActivity eventTraceActivity)
Process Name: w3wp
Process ID: 4248
I see there are a lot of plugins for Java but I am posting here to see if anyone already is doing so and can provide some advice on setting up such a monitoring check. All our servers are running NRPE or NSClient++. It would have been nice to get notified on this before the application failed.
The error that you are seeing should be mitigated by checking the memory usage of the windows system, are you currently doing that? If so, what did it say during that time?
If you look at this post you should be able to get the working set memory and determine that there is a problem if it hits a threshold but I'm not seeing a plugin currently written that would do this.
From the research I've done that is based on total memory of the system so it should have showed the memory usage as high during that timeperiod unless it occurred between when your memory usage checks in XI occurred.
