[Sun Apr 24 03:28:29 2016] [error] [client 172.27.15.48] PHP Warning: pg_pconnect(): Unable to connect to PostgreSQL server: could not connect to server: Connection refused\n\tIs the server running on host "localhost" and accepting\n\tTCP/IP connections on port 5432?\ncould not connect to server: Connection refused\n\tIs the server running on host "localhost" and accepting\n\tTCP/IP connections on port 5432? in /usr/local/nagiosxi/html/db/adodb/drivers/adodb-postgres64.inc.php on line 682, referer: http://nagios.selic.bc/nagiosxi/includes/components/nocscreen/noc.php
[Sun Apr 24 03:28:29 2016] [error] [client 172.27.15.48] PHP Notice: Undefined variable: result in /usr/local/nagiosxi/html/includes/db.inc.php on line 249, referer: http://nagios.selic.bc/nagiosxi/includes/components/nocscreen/noc.php
[Sun Apr 24 03:28:29 2016] [error] [client 172.27.15.178] PHP Warning: pg_pconnect(): Unable to connect to PostgreSQL server: could not connect to server: Connection refused\n\tIs the server running on host "localhost" and accepting\n\tTCP/IP connections on port 5432?\ncould not connect to server: Connection refused\n\tIs the server running on host "localhost" and accepting\n\tTCP/IP connections on port 5432? in /usr/local/nagiosxi/html/db/adodb/drivers/adodb-postgres64.inc.php on line 682, referer: http://nagios.selic.bc/nagiosxi/includes/components/xicore/status.php?show=servicedetail&host=libracont.selic.bc&service=mainframe_metering_15&dest=auto
Any idea of what is causing this and how it can be fixed?
You can download your profile by going to Admin > System Config > System Profile and click the Download Profile button in the top right corner. Then just PM it to one of use by clicking on one of our names and then click the "Send a private message" link, make sure to click "Add the file" after you select your profile.
