I am extracting numeric values from log messages. How can I graph the actual values (not how many times that they occur)?
I've tried with the following but no luck. I am still getting graphs based on how many times that the value occurs in the messages rather than the actual number.
# Partial filter
%{NUMBER:value:int}
Thanks in advance.
How to graph numeric values from messages
Re: How to graph numeric values from messages
You you extracting the portion of the text that contains the number must be parsed into its own field. Then you can graph that field as a number. The basic of how to do this are explained in https://www.elastic.co/guide/en/logstas ... -grok.html, and there are a lot of examples on the web. If you have specific examples you can share about your data, we may be able to help you provide a working filter expression.
Assuming that you are extracting the number into its own field, and you want to graph that number itself, then one option is to make a histogram using the field that you are for as its field value and a chart type of "total." Look at the Apache Dashboard that came with NLS for some inspiration on how you can graph numbers or totals of numbers.
Also, can you please provide a screenshot of the log, and possibly a mock-up of how you want this done?
Former Nagios Employee.
me.
me.
Thanks to both of you. I've changed chart value/type to "mean" (instead of the default value "count") and I was able to generate the graph I wanted.
1) Yes, I am extracting the portion of the text that contains the number.
2) Correct, I want to graph the number itself.
Thanks again.
Thanks again.
Are we good to mark this thread as resolved?
