I get the errors on the attachment but it states the command completed successfully.
As far as I can tell its working but not sure why these errors pop up, happens for all users too.
This is version 1.7 pre-built VM.
Thanks!
sql errors on update user settings
Re: sql errors on update user settings
Those might be just normal errors that wouldn't otherwise be shown. What does the result of this command return?
cat /etc/php.ini | grep 'display_errors =' | grep -v ';'Nicholas Scott
display_errors = Off
Actually, we have a bug report on this - check it out here:
http://tracker.nagios.com/view.php?id=194
It is already fixed and probably we will be releasing a development edition sometime by the end of the next week.
