Active and Passive (NSCA) Results stop updating...
larrydhelms
Post by larrydhelms »
Both Active and Passive (via NSCA) results stop updating...
We're running:
Nagios 5.2.3 (Core Nagios 4.1.1)
NSCA (Version: 2.9.1)
NRPE
NSClient++ (.4.4.19 on Windows hosts)
mod_gearman for distributed active checks (version 1.5.0b1 (libgearman 1.1.8))
What we are seeing... is that the Last Check column - in the UI (under Service Detail)... and Graphing results... cease to update.
I wrote a check... to alert when Last Check information stops updating... I use this SQL to check
The time between problems is NOT consistent. The only solution seems to be stop Nagios... and restart it.
Please advise as to what configs/log files you would like me to send/attach.
larrydhelms
Re: Active and Passive (NSCA) Results stop updating...
Also... I've already check this...
https://support.nagios.com/kb/article.php?id=19
and we are not suffering from Table Corruptions, multiple errant nagios processes or /etc/security/limits.conf issues... and auto rescheduling is disabled.
Can you send us your profile (Admin->System Profile->Download Profile) to [email protected]? We will need to look through your configuration and log files.
larrydhelms
Have sent the requested information... via eMail.
When did you send your email? What is the email that you sent it from?
I don't see your email in our ticketing system yet.
