Modifying elasticsearch.yml
Frodo
Post by Frodo »
Does Nagios Log Server support any method to manage elasticsearch.yml in a cluster?
We are looking into change discovery.zen.minimum_master_nodes for instance.
Our concern is that future upgrades might clobber these changes if we do it directly in the files.
hsmith
Agent Smith
Re: Modifying elasticsearch.yml
Post by hsmith »
Editing it via the terminal should be fine. I modified mine, and upgraded from 1.4.0 --> 1.4.1. I can't promise that it won't be wiped out on a major upgrade, but right now the behavior is that it's not replaced.
Former Nagios Employee.
me.
