check_disk disable critical
[email protected]
Post by [email protected] »
I am new to configuring Nagios alerting and need some help on what is probably a simple fix. I have file system monitoring setup and working fine in my environment but I need to modify it for our DEV/QA areas. Currently we get a warning level alert at 90% full and critical at 95%. I need to get rid of critical all together. We want to know when a FS gets above a certain threshold with a warning alert but even if it reaches 100% it is still not considered a "critical" event in this area. Any suggestions?
# 'DEV File System' command definition
command_name DEV_check_local_disk
command_line $USER1$/check_nrpe -H $HOSTADDRESS$ -t 30 -c check_disk -a $ARG1$ $ARG2$ $ARG3$
use dev_default-service
service_description DEV FS: /
check_command DEV_check_local_disk!10%!5%!/
contact_groups TEST-CG
servicegroups DEV_FS_Root-SG
Re: check_disk disable critical
It sounds like you would need to modify the plugin directly, and see if you can have it just exit on a WARNING instead of CRITICAL.
You could use your negate plugin, to switch CRIT -> WARN - take a look at this document for more information https://assets.nagios.com/downloads/nag ... ios-XI.pdf
Another option is to add a notification option to that service and only send them out for warnings and recoveries like the example below.
notification_options		w,r,
Post by mcapra »
You could try leaving the critical threshold undefined like so:
        check_command        DEV_check_local_disk!10%!!/
This works for me in core for check_local_disk. Your results may vary depending on your DEV_check_local_disk behavior.
[email protected]
I have been playing around with this and no luck so far. I tried the "check_command DEV_check_local_disk!10%!!/" recommendation and it just threw and error saying I had to define a criteria for critical
I even tried giving it a negative value to try and fool it and it really disliked that.
As for the notification suggestion the problem there is if it goes straight to critical no one will get notified about it which would be a problem.
Take a look at the Exchange site to see if there are other disk checks that have optional thresholds.
https://exchange.nagios.org/
Post by mcapra »
I notice the command definition for DEV_check_local_disk is asking for 3 args in a non-specific way
You could try explicitly declaring the arguments you are sending to the remote machine's check_disk script like so:
    command_line       $USER1$/check_nrpe -H $HOSTADDRESS$ -t 30 -c check_disk -a '-w $ARG1$ -p $ARG2$'
Notice how I am telling the check_disk command on the remote machine exactly what each argument is used for. I am saying $ARG1$ is used for the "warning" threshold and $ARG2$ is being used for the "path".
Your service definition should change accordingly:
        check_command        DEV_check_local_disk!10%!/
The check_command field for a service definition feeds in arguments in a sequential fashion following a ! character. Eg, DEV_check_local_disk!$ARG1$!$ARG2!$ARG3 ... !$ARGN
[email protected] wrote:I had to define a criteria for critical
I believe this is because your current command definition is trying to send the remote machine's check_disk 3 arguments (in a non specific way) when all you really need is 2 arguments (sent in a specific way): The warning threshold and the path
[email protected]
Through the help and guidance of everyone on here I finally found the solution. Probably not the only solution but we have verified it works. It was a little rough figuring out that i needed a space before the -w otherwise it was trying to check /local-w. This is now working flawlessly. Thank you everyone for all of your help.
service_description DEV FS: /local
check_command DEV_check_local_disk!'-p /local'' -w 10%'
servicegroups DEV_FS_Local-SG
Post by mcapra »
Glad to hear you were able to find a solution! Can I lock this thread and mark the issue as resolved?
[email protected]
You can. And again thanks to everyone who assisted with this.
