Mongo Monitoring Wizard.
Please we need help in setting up our mongo servers for monitoring in nagios, using the mongo wizard.Whenever we want to setup the monitoring, the wizard prompts us to install pymongo on the xi server, which we have already done on two occasions.
Thank you,
Ola Adeiga.
Thank you,
Ola Adeiga.
Re: Mongo Monitoring Wizard.
What version of Xi are you running? I just ran through both of the mongo wizards on a 5.2.7 test machine here and did not encounter the prompts you mention.
Have you referred to either of these docs?
Nagios XI - Monitoring MongoDB
https://support.nagios.com/kb/article.php?id=251
Also, what is the version of the Mongo wizards? In the XI GUI go to:
Admin > System Extensions > Manage Config Wizards
Our nagios is up to date also, it's 5.2.7. The Mongodb wizard server version 1.0.3, and the version for the database is 1.0.1.
What issues are you currently seeing? Can you show us screenshots?
Error: It looks like you are missing pymongo on your Nagios XI server.
To use this wizard you must install pymongo on your server. If you are using CentOS or RHEL you can run "yum install pymongo".
The above is the error we are witnessing, and pymongo is already installed on our xi server.
I wonder if it's a version thing, both wizards seem to be running fine on my end. What is the output of rpm -qa | grep 'mongo'?
For reference, here's the output on my system -
[root@localhost ~]# rpm -qa | grep 'mongo'
python-pymongo-2.5.2-4.el7.x86_64
What is the output of these commands?
Thank you
ls -l /usr/local/nagios/libexec/check_mongodb.py
/usr/local/nagios/libexec/check_mongodb.py | head --lines=1Thank you
Actually, edit this file:
Change line 310 from:
To:
Let us know if that works for you.
/usr/local/nagios/libexec/check_mongodb.pyCode: Select all
if e.split() == "not master":Code: Select all
if e == "not master":Re: Mongo Monitoring Wizard.
Hi, I couldn't locate the line 310 of check_mongodb.py to edit... But below is the output of the specified commands;
ls -l check_mongodb.py
-rwxr-xr-x 1 nagios nagios 62494 May 6 11:52 check_mongodb.py
Can you run the following commands and post the output?
su nagios
/usr/local/nagios/libexec/check_mongodb.py --help
find / -name pymongo
ls -l /usr/lib64/python2.7/site-packages/Be sure to check out our Knowledgebase for helpful articles and solutions!
