Website Defacement
raamardhani7
Website Defacement
Post by raamardhani7 »
Hi Team,
We are looking in depth monitoring for website.
Scenario1: there will be content written in the website by the owner and there might be hackers who modifies that content, tool should report that the content is modified by someone?
Senarios2: Website redirection, if I am using www.nagios.com and hacker prepares similar webpage and is redirecting my page to www.naagios.com (extra a added in nagios), which I may not notice, wanted to have this reported too.?
Will Nagios be able to do capture these details? Could you please help me here. this is at highest requirement for us. thanks.
Re: Website Defacement
You will want to use the -r flag to match regex -
 -r, --regex, --ereg=STRING
    Search page for regex STRING
As for the redirection, if you use the -f parameter then i will follow redirections, if you don't then it won't. You'll want to specify a code to expect as well which is -e -
 -e, --expect=STRING
    Comma-delimited list of strings, at least one of them is expected in
    the first (status) line of the server response (default: HTTP/1.)
    If specified skips all other status line logic (ex: 3xx, 4xx, 5xx processing)
raamardhani7
rkennedy wrote:You will want to use the -r flag to match regex -
 -e, --expect=STRING
Hi Rkennedy,
thanks a lot for the information, you can close this thread.
